Datasheet Texas Instruments TXB0108ZXYR — Даташит
СерияTXB0108
МодельTXB0108ZXYR
8-битный двунаправленный преобразователь уровня напряжения с автоматическим определением направления и защитой от электростатического разряда +/-15 кВ 20-BGA MICROSTAR JUNIOR от -40 до 85
TXB0108 8-Bit Bidirectional Voltage-Level Translator with Auto-Direction Sensing and В±15-kV ESD Protection datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 14 ноя 2014
Pin20
Package TypeZXY
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeS-PBGA-N
Package QTY2500
МаркировкаYE08
Width (мм)3
Length (мм)2.5
Thickness (мм).36
Pitch (мм).5
Max Height (мм).61
Bits8
F @ Nom Voltage(Max)50 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Max Drive50 мА
Package GroupBGA MICROSTAR JUNIOR
Package Size: mm2:W x L20BGA MICROSTAR JUNIOR: 8 mm2: 3 x 2.5(BGA MICROSTAR JUNIOR) PKG
Schmitt TriggerNo
Technology FamilyTXB
VCCA(Max)3.6 В
VCCA(Min)1.2 В
VCCB(Max)5.5 В
VCCB(Min)1.65 В
Voltage(Nom)1.2,1.5,1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)4.9,4 нс
  • Evaluation Modules & Boards: TMDXEVM368
    TMS320DM36x Evaluation Module
  • A Guide to Voltage Translation With TXB-Type Translators
    PDF, 102 Кб, Файл опубликован: 3 мар 2010
    Modern trends are driving the need for lower supply voltages across many system-level designs. As most processor voltage levels continue to decrease in the interest of achieving the lowest possible power consumption, peripheral devices maintain a need for higher voltage levels, creating potential for voltage discontinuities within a system. To remedy this mixed voltage system incompatibility, a vo
  • Effects of pullup and pulldown resistors on TXS and TXB devices
    PDF, 732 Кб, Файл опубликован: 20 сен 2017
    The TXS and TXB family of devices belong to the auto-bidirectional translation products from TI. These devices can be sensitive to external pullup or pulldown resistors due to the internal pullup resistors present in the TXS device and the internal serial resistors present in the TXB device. In this application note, the effects of external pullup and pulldown resistors on VOL and VOH levels of th
  • A Guide to Voltage Translation With TXS-Type Translators
    PDF, 287 Кб, Файл опубликован: 29 июн 2010
  • Semiconductors > Logic > Voltage Level Translation > Bidirectional Voltage Translation
На английском языке: Datasheet Texas Instruments TXB0108ZXYR
