0.560-INCH SEVEN SEGMENT DISPLAYS HIGH EFFICIENCY GREEN MAN6400 SERIES
PACKAGE DIMENSIONS
.985" (25.02 mm) ±.010" .500" (12.70 mm) A .750" (19.05 mm) +.010" F .560" (14.22 mm) E .066" DIA (1.68 mm) LIGHT INTENSITY CAT. .160" (4.06 mm) +.015" G D B C DP F E A G D B C DP Description
The MAN6400 Series is a family of large digits which includes double and single digits. The series features the sculptured font which minimizes "gappiness" at the segment intersections. All models have right hand decimal points and are available in common anode or common cathode configuration. This device has a Grey face and clear segments to enhance ON and OFF contrast. DIGIT = 1 PART IDENTIFICATION .320" (8.13 mm) PART NO. 8° DATE CODE XYY Z Features High Efficiency Green nitrogen-doped GaAsP on GaP Large, easy to read, digits Common anode or common cathode models Fast switching -excellent for multiplexing Low power consumption Bold solid segments that are highly legible Solid state reliability -long operation life Rugged plastic construction Directly compatible with integrated circuits High brightness with high contrast Categorized for Luminous Intensity (See Note 5) Wide angle viewing.150° Low forward voltage Two-digit package simplifies alignment and assembly .315" (8.00 mm) ±.010" .050" +.004" -.000" (1.27 mm) PIN #1 (NOTE SQUARE .100" (2.54 mm) BASE ON LEAD) .020" (0.51 mm) +.004" -.000" .600" (15.24 mm) +.015" .010" (0.25 mm) +.007" -.000" .480" (12.20 mm) ±.010" A .750" (19.05 mm) +.010" .560" +0.010" (14.22 mm) F E G D B C DP .320" (8.13 mm) PART IDENTIFICATION .066" DIA 8° LIGHT INTENSITY CAT. DATE CODE PART NO. XYY Z .315" (8.00 mm) ±.010" .050" (1.27 mm) .020" (0.51 mm) +.004" -.000" .160" (4.06 mm) +.015" Applications
For industrial and consumer applications such as: Digital readout displays Instrument panels Point of sale equipment Digital clocks TV and radios PIN #1 .100" TYP (2.54 mm) PIN #5 .600" (15.24 mm) +.015" .010" (0.25 mm) +.007" -.000" MODEL NUMBERS
Part Number MAN6410 MAN6440 MAN6460 MAN6980 Color High Eff. Green High Eff. Green High Eff. Green High Eff. Green Description 2 Digit; Common Anode; Rt. Hand Decimal 2 Digit; Common Cathode; Rt. Hand Decimal Single Digit; Common Anode; Rt. Hand Decimal Single Digit; Common Cathode; Rt. Hand Decimal Package Drawing A A B B Pin Out Specification A B C D © 2003 Fairchild Semiconductor Corporation Page 1 of 6 7/16/03 0.560-INCH SEVEN SEGMENT DISPLAYS HIGH EFFICIENCY GREEN MAN6400 SERIES
RECOMMENDED OPTICAL FILTERS
For optimum ON and OFF contrast, one of the following filters or equivalents should be used over t …
