Datasheet Texas Instruments TL072CPSRG4 — Даташит
Серия | TL072 |
Модель | TL072CPSRG4 |
Двойной малошумящий операционный усилитель общего назначения с входом JFET 8-SO 0–70
TL07xx Low-Noise JFET-Input Operational Amplifiers datasheet
PDF, 2.7 Мб, Версия: N, Файл опубликован: 26 июл 2017
Pin | 8 |
Package Type | PS |
Industry STD Term | SOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | T072 |
Width (мм) | 5.3 |
Length (мм) | 6.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
Архитектура | FET |
CMRR(Min) | 70 дБ |
CMRR(Typ) | 100 дБ |
Основные особенности | Standard Amps |
GBW(Typ) | 3 МГц |
Input Bias Current(Max) | 200 pA |
Iq per channel(Max) | 2.5 мА |
Iq per channel(Typ) | 1.4 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 18 uV/C |
Рабочий диапазон температур | от -40 до 85,0 до 70 C |
Output Current(Typ) | 10 мА |
Package Group | SO |
Package Size: mm2:W x L | 8SO: 48 mm2: 7.8 x 6.2(SO) PKG |
Rail-to-Rail | In to V+ |
Rating | Catalog |
Slew Rate(Typ) | 13 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 18 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 6 мВ |
- Understanding Operational Amplifier SpecificationsPDF, 273 Кб, Файл опубликован: 13 июл 1998
Selecting the right operational amplifier for a specific application requires you to have your design goals clearly in mind along with a firm understanding of what the published specifications mean. This paper addresses the issue of understanding data sheet specifications.This paper begins with background information. First introductory topics on the basic principles of amplifiers are presen - Handbook of Operational Amplifier Applications (Rev. B)PDF, 2.8 Мб, Версия: B, Файл опубликован: 19 сен 2016
While in the process of reviewing Texas Instruments applications notes including those from Burr-Brown - I uncovered a couple of treasures this handbook on op amp applications and one on active RC networks. These old publications from 1963 and 1966 respectively are some of the finest works on op amp theory that I have ever seen. Nevertheless they contain some material that is hopelessly outd - Stability Analysis Of Voltage-Feedback Op Amps Including Compensation Technique (Rev. A)PDF, 197 Кб, Версия: A, Файл опубликован: 12 мар 2001
This report presents an analysis of the stability of voltage-feedback operational amplifiers (op amps) using circuit performance as the criteria to attain a successful design. It discusses several compensation techniques for op amps with and without internal compensation.
Серия: TL072 (23)
- Semiconductors > Analog and Mixed-Signal > Amplifiers > Operational Amplifiers (Op Amps) > General-Purpose Op Amps
