Оптопары и оптореле Megawin
Datasheet Texas Instruments TL072IDG4 — Даташит
СерияTL072
МодельTL072IDG4
Двойной малошумящий операционный усилитель общего назначения с входом JFET 8-SOIC от -40 до 85
TL07xx Low-Noise JFET-Input Operational Amplifiers datasheet
PDF, 2.7 Мб, Версия: N, Файл опубликован: 26 июл 2017
Package TypeD
Package QTY75
МаркировкаTL072I
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
АрхитектураFET
CMRR(Min)70 дБ
CMRR(Typ)100 дБ
Основные особенностиStandard Amps
GBW(Typ)3 МГц
Input Bias Current(Max)200 pA
Iq per channel(Max)2.5 мА
Iq per channel(Typ)1.4 мА
Количество каналов2
Offset Drift(Typ)18 uV/C
Output Current(Typ)10 мА
Rail-to-RailIn to V+
Slew Rate(Typ)13 V/us
Total Supply Voltage(Min)7 +5V=5, +/-5V=10
Vn at 1kHz(Typ)18 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)6 мВ
  • Understanding Operational Amplifier Specifications
    PDF, 273 Кб, Файл опубликован: 13 июл 1998
    Selecting the right operational amplifier for a specific application requires you to have your design goals clearly in mind along with a firm understanding of what the published specifications mean. This paper addresses the issue of understanding data sheet specifications.This paper begins with background information. First introductory topics on the basic principles of amplifiers are presen
  • Handbook of Operational Amplifier Applications (Rev. B)
    PDF, 2.8 Мб, Версия: B, Файл опубликован: 19 сен 2016
    While in the process of reviewing Texas Instruments applications notes including those from Burr-Brown - I uncovered a couple of treasures this handbook on op amp applications and one on active RC networks. These old publications from 1963 and 1966 respectively are some of the finest works on op amp theory that I have ever seen. Nevertheless they contain some material that is hopelessly outd
  • Stability Analysis Of Voltage-Feedback Op Amps Including Compensation Technique (Rev. A)
    PDF, 197 Кб, Версия: A, Файл опубликован: 12 мар 2001
    This report presents an analysis of the stability of voltage-feedback operational amplifiers (op amps) using circuit performance as the criteria to attain a successful design. It discusses several compensation techniques for op amps with and without internal compensation.
  • Semiconductors > Analog and Mixed-Signal > Amplifiers > Operational Amplifiers (Op Amps) > General-Purpose Op Amps
На английском языке: Datasheet Texas Instruments TL072IDG4
