Datasheet Texas Instruments TL071CPWLE — Даташит
| Серия | TL071 |
| Модель | TL071CPWLE |
Малошумящий операционный усилитель общего назначения с входом JFET 8-TSSOP от 0 до 70
TL07xx Low-Noise JFET-Input Operational   Amplifiers datasheet
PDF, 2.7 Мб, Версия: N, Файл опубликован: 26 июл 2017
| TL071CPWLE | по запросу | ||
| TL071CPWLE Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 8 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Width (мм) | 4.4 |
| Length (мм) | 3 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Additional Features | Vos Adj Pin |
| Approx. Price (US$) | 0.12 | 1ku |
| Архитектура | FET |
| CMRR(Min)(dB) | 70 |
| CMRR(Typ)(dB) | 100 |
| GBW(Typ)(MHz) | 3 |
| Input Bias Current(Max)(pA) | 200 |
| Iq per channel(Max)(mA) | 2.5 |
| Iq per channel(Typ)(mA) | 1.4 |
| Number of Channels(#) | 1 |
| Offset Drift(Typ)(uV/C) | 18 |
| Operating Temperature Range(C) | -40 to 85 0 to 70 |
| Output Current(Typ)(mA) | 10 |
| Package Group | SO |
| Package Size: mm2:W x L (PKG) | See datasheet (CDIP) See datasheet (PDIP) |
| Rail-to-Rail | In to V+ |
| Rating | Catalog |
| Slew Rate(Typ)(V/us) | 13 |
| Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 36 |
| Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 7 |
| Vn at 1kHz(Typ)(nV/rtHz) | 18 |
| Vos (Offset Voltage @ 25C)(Max)(mV) | 6 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Understanding Operational Amplifier SpecificationsPDF, 273 Кб, Файл опубликован: 13 июл 1998
 Selecting the right operational amplifier for a specific application requires you to have your design goals clearly in mind along with a firm understanding of what the published specifications mean. This paper addresses the issue of understanding data sheet specifications.This paper begins with background information. First introductory topics on the basic principles of amplifiers are presen
- Handbook of Operational Amplifier Applications (Rev. B)PDF, 2.8 Мб, Версия: B, Файл опубликован: 19 сен 2016
 While in the process of reviewing Texas Instruments applications notes including those from Burr-Brown - I uncovered a couple of treasures this handbook on op amp applications and one on active RC networks. These old publications from 1963 and 1966 respectively are some of the finest works on op amp theory that I have ever seen. Nevertheless they contain some material that is hopelessly outd
- Stability Analysis Of Voltage-Feedback Op Amps Including Compensation Technique (Rev. A)PDF, 197 Кб, Версия: A, Файл опубликован: 12 мар 2001
 This report presents an analysis of the stability of voltage-feedback operational amplifiers (op amps) using circuit performance as the criteria to attain a successful design. It discusses several compensation techniques for op amps with and without internal compensation.
Серия: TL071 (21)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > General-Purpose Op Amps
