Datasheet Texas Instruments TPS62085RLTT — Даташит
СерияTPS62085
МодельTPS62085RLTT
Понижающий преобразователь 3-А с DCS-управлением и защитой от короткого замыкания в корпусе HotRod 2x2 7-VSON-HR от -40 до 125
TPS6208x 3-A Step-Down Converter With Hiccup Short-Circuit Protection In 2 Г— 2 QFN Package datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 25 июн 2015
Pin7
Package TypeRLT
Industry STD TermVSON-HR
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаPD5Q
Width (мм)2
Length (мм)2
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Control ModeConstant on-time (COT)
Duty Cycle(Max)100 %
Iout(Max)3 A
Iq(Typ)0.017 мА
Package GroupVSON-HR
Regulated Outputs1
Special FeaturesEnable,Light Load Efficiency,Output Discharge,Power Good,Synchronous Rectification
Switching Frequency(Max)2400 kHz
Switching Frequency(Min)2400 kHz
ТипConverter
Vin(Max)6 В
Vin(Min)2.5 В
Vout(Max)6 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: TPS62085EVM-169
    TPS62085EVM-169 3-A Step-Down Converter with DCS-Control and Hiccup Short Circuit Evaluation Module
  • Evaluation Modules & Boards: ADC32RF44EVM
    ADC32RF44 Dual-Channel, 14-Bit, 2.6GSPS, RF-Sampling ADC Evaluation Module
  • Evaluation Modules & Boards: ADC32RF42EVM
    ADC32RF42 Dual-Channel, 14-Bit, 1.5GSPS, RF-Sampling ADC Evaluation Module
  • Evaluation Modules & Boards: ADS58J64EVM
    ADS58J64 Evaluation Module
  • Evaluation Modules & Boards: ADC32RF82EVM
    ADC32RF82 Dual-Channel, 14-Bit, 2.45GSPS Telecom Receiver and Feedback IC Evaluation Module
  • Evaluation Modules & Boards: DAC38RF89EVM
    DAC38RF89 Dual-Channel, 14-Bit, 8.4GSPS, 1x-24x Interpolating, 5 & 7.5 GHz PLL DAC Evaluation Module
  • Evaluation Modules & Boards: DAC38RF86EVM
    DAC38RF86 Dual-Channel, 14-Bit, 9-GSPS, 6x-24x Interpolating, 9 GHz GSM PLL DAC Evaluation Module
  • Evaluation Modules & Boards: DAC38RF87EVM
    DAC38RF87 Dual-Channel, 14-Bit, 6.2-GSPS, 6x-24x Interpolating, 6-GHz GSM PLL DAC Evaluation Module
  • Evaluation Modules & Boards: DAC38RF80EVM
    DAC38RF80 Dual-Channel, 14-Bit, 9-GSPS, 6x-24x Interpolating, 6 & 9 GHz PLL DAC Evaluation Module
  • Evaluation Modules & Boards: DAC38RF82EVM
    DAC38RF82 Dual-Channel, 14-Bit, 9-GSPS, 1x-24x Interpolating, 6 & 9 GHz PLL DAC Evaluation Module
  • Analog Applications Journal 4Q 2014
    PDF, 1.8 Мб, Файл опубликован: 24 окт 2014
  • Power-supply sequencing for FPGAs
    PDF, 771 Кб, Файл опубликован: 24 окт 2014
  • How to Measure the Control Loop of DCS-Control Devices (Rev. A)
    PDF, 259 Кб, Версия: A, Файл опубликован: 9 авг 2012
  • High-efficiency low-ripple DCS-Control offers seamless PWM/pwr-save transitions
    PDF, 605 Кб, Файл опубликован: 25 июл 2013
  • Understanding frequency variation in the DCS-Control(TM) topology
    PDF, 224 Кб, Файл опубликован: 30 окт 2015
  • Design considerations for a resistive feedback divider in a DC/DC converter
    PDF, 393 Кб, Файл опубликован: 26 апр 2012
  • Five steps to a great PCB layout for a step-down converter
    PDF, 162 Кб, Файл опубликован: 29 янв 2015
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
  • Testing tips for applying external power to supply outputs without an input volt
    PDF, 110 Кб, Файл опубликован: 24 окт 2016
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: TPS62085 (2)
На английском языке: Datasheet Texas Instruments TPS62085RLTT
