Datasheet Texas Instruments TL081IDR — Даташит
СемействоTL08xx
СерияTL081
МодельTL081IDR
Операционный усилитель с входом JFET 8-SOIC от -40 до 85
Datasheet TL081, TL081A, TL081B, TL082, TL082A, TL082B, TL084, TL084A, TL084B
PDF, 2.5 Мб, Версия: I, Файл опубликован: 27 май 2015, Страниц: 51
TL08xx JFET-input operational amplifier
53 предложений от 22 поставщиков
TL081IDRE4
11 ₽
Microfind
TL081IDR
13 ₽
TL081IDR
от 26 ₽
TradeElectronics
TL081IDR
Package TypeD
Package QTY2500
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
АрхитектураFET
CMRR(Min)70 дБ
CMRR(Typ)86 дБ
Основные особенностиN/A
GBW(Typ)3 МГц
Input Bias Current(Max)200 pA
Iq per channel(Max)2.8 мА
Iq per channel(Typ)1.4 мА
Количество каналов1
Offset Drift(Typ)18 uV/C
Output Current(Typ)10 мА
Rail-to-RailIn to V+
Slew Rate(Typ)13 V/us
Total Supply Voltage(Min)7 +5V=5, +/-5V=10
Vn at 1kHz(Typ)18 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)6 мВ
  • Compensation Methodology for Error in SK Low-Pass Filter Caused by Limited GBW
    PDF, 261 Кб, Файл опубликован: 18 июл 2017
    This application report provides a tutorial description of the error analysis for the Sallen-Key active low-pass filter.Additionally the report introduces a new compensation method to reduce the errors caused by the limitedgain-bandwidth of an op amp. Simulation and test data which demonstrate the performance achieved with thiscompensation technique are presented.
  • Stability Analysis Of Voltage-Feedback Op Amps Including Compensation Technique (Rev. A)
    PDF, 197 Кб, Версия: A, Файл опубликован: 12 мар 2001
    This report presents an analysis of the stability of voltage-feedback operational amplifiers (op amps) using circuit performance as the criteria to attain a successful design. It discusses several compensation techniques for op amps with and without internal compensation.
На английском языке: Datasheet Texas Instruments TL081IDR
