Datasheet Texas Instruments TL084CJ — Даташит
СемействоTL08xx
СерияTL084
МодельTL084CJ
Операционный усилитель с входом JFET 14-CDIP 0–70
Datasheet TL081, TL081A, TL081B, TL082, TL082A, TL082B, TL084, TL084A, TL084B
PDF, 2.5 Мб, Версия: I, Файл опубликован: 27 май 2015, Страниц: 51
TL08xx JFET-input operational amplifier
Pin14
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.67
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesN/A
Approx. Price (US$)0.13 | 1ku
АрхитектураFET
CMRR(Min)(dB)70
CMRR(Typ)(dB)86
GBW(Typ)(MHz)3
Input Bias Current(Max)(pA)200
Iq per channel(Max)(mA)2.8
Iq per channel(Typ)(mA)1.4
Number of Channels(#)4
Offset Drift(Typ)(uV/C)18
Operating Temperature Range(C)-40 to 125
-40 to 85
0 to 70
Output Current(Typ)(mA)10
Package GroupPDIP
SO
SOIC
TSSOP
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
See datasheet (PDIP)
Rail-to-RailIn to V+
Slew Rate(Typ)(V/us)13
Total Supply Voltage(Max)(+5V=5, +/-5V=10)36
Total Supply Voltage(Min)(+5V=5, +/-5V=10)7
Vn at 1kHz(Typ)(nV/rtHz)18
Vos (Offset Voltage @ 25C)(Max)(mV)6
RoHSНе совместим
  • Stability Analysis Of Voltage-Feedback Op Amps Including Compensation Technique (Rev. A)
    PDF, 197 Кб, Версия: A, Файл опубликован: 12 мар 2001
    This report presents an analysis of the stability of voltage-feedback operational amplifiers (op amps) using circuit performance as the criteria to attain a successful design. It discusses several compensation techniques for op amps with and without internal compensation.
На английском языке: Datasheet Texas Instruments TL084CJ
