Datasheet ON Semiconductor MC14543BDG — Даташит
Производитель | ON Semiconductor |
Серия | MC14543B |
Модель | MC14543BDG |
Защелка/декодер/драйвер сегментов BCD-to-Seven для жидких кристаллов
MC14543B BCD-to-Seven Segment Latch/Decoder/Driver for Liquid Crystals
The MC14543B BCD-to-seven segment latch/decoder/driver is designed for use with liquid crystal readouts, and is constructed with complementary MOS (CMOS) enhancement mode devices. The circuit provides the functions of a 4-bit storage latch and an 8421 BCD-to-seven segment decoder and driver. The device has the capability to invert the logic levels of the output combination. The phase (Ph), blanking (BI), and latch disable (LD) inputs are used to reverse the truth table phase, blank the display, and store a BCD code, respectively. For liquid crystal (LC) readouts, a square wave is applied to the Ph input of the circuit and the electrically common backplane of the display. The outputs of the circuit are connected directly to the segments of the LC readout. For other types of readouts, such as light-emitting diode (LED), incandescent, gas discharge, and fluorescent readouts, connection diagrams are given on this data sheet. Applications include instrument (e.g., counter, DVM etc.) display driver, computer/calculator display driver, cockpit display driver, and various clock, watch, and timer uses.
Features http://onsemi.com 1 SOIC-16 D SUFFIX CASE 751B PIN ASSIGNMENT
LD C B D A PH BI VSS 1 2 3 4 5 6 7 8 16 15 14 13 12 11 10 9 VDD f g e d c b a Latch Storage of Code Blanking Input Readout Blanking on All Illegal Input Combinations Direct LED (Common Anode or Cathode) Driving Capability Supply Voltage Range = 3.0 V to 18 V Capable of Driving 2 Low-power TTL Loads, 1 Low-power Schottky TTL Load or 2 HTL Loads Over the Rated Temperature Range Pin-for-Pin Replacement for CD4056A (with Pin 7 Tied to VSS). Chip Complexity: 207 FETs or 52 Equivalent Gates NLV Prefix for Automotive and Other Applications Requiring Unique Site and Control Change Requirements; AEC-Q100 Qualified and PPAP Capable. This Device is Pb-Free and is RoHS Compliant MARKING DIAGRAM
16 14543BG AWLYWW 1 A WL, L YY, Y WW, W G = Assembly Location = Wafer Lot = Year = Work Week = Pb-Free Package ORDERING INFORMATION
See detailed ordering and shipping information in the package dimensions section on page 7 of this data sheet. © Semiconductor Components Industries, LLC, 2014 1 July, 2014 -Rev. 10 Publication Order Number: MC14543B/D MC14543B
MAXIMUM RATINGS (Voltages Referenced to VSS)
Parameter DC Supply Voltage Range Input Voltage Range, All Inputs DC Input Current per Pin Power Dissipation per Package (Note 1) Operating Temperature Range Storage Temperature Range Maximum Continuous Output Drive Current (Source or Sink) Maximum C …
- MC14543BDG
- Standard Logic > Latches & Registers
