Datasheet Texas Instruments LM555CMM — Даташит
СерияLM555
МодельLM555CMM
Высокостабильный таймер 555 для точной генерации временных задержек и колебаний 8-VSSOP от 0 до 70
LM555 Timer datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 21 окт 2014
Package TypeDGK
Industry STD TermVSSOP
Package QTY1000
CarrierSMALL T&R
МаркировкаZ55
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Рекомендуемая замена
ReplacementLM555CMM/NOPB
Replacement CodeS
Frequency(Max)0.1 МГц
Iq(Typ)3000 uA
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
VCC(Max)16 В
VCC(Min)4.5 В
RoHSSee ti.com
  • HS Load/Line Transient Jigs and App Rpt for Testing POL Regulators
    PDF, 1.9 Мб, Файл опубликован: 30 апр 2013
    These days, high-speed and communication portable systems employ voltage regulators that demandfaster response time. It is necessary to generate steps in line voltage and load current that are fast withrespect to the regulator’s control loop response time. Lab equipment and many apparatus that use opamps,passives, and large driver chains are limiting the rise and fall times of the stimulus s
  • AN-694 A DMOS 3A, 55V, H-Bridge: The LMD18200 (Rev. C)
    PDF, 604 Кб, Версия: C, Файл опубликован: 26 апр 2013
    This application note provides information on the LMD18200, which is optimized to work for applicationsthat require 0.5A to 3.0A and operate from 12V to 55V.
  • Semiconductors > Clock and Timing > Timers
На английском языке: Datasheet Texas Instruments LM555CMM
