Datasheet Texas Instruments TPS548D22RVFT — Даташит
СерияTPS548D22
МодельTPS548D22RVFT
Синхронный понижающий преобразователь SWIFT от 1,5 до 16 В, 40 А с полным дифференциальным считыванием 40-LQFN-CLIP от -40 до 125
TPS548D22 1.5-V to 16-V VIN, 4.5-V to 22-V VDD, 40-A SWIFTв„ў Synchronous Step-Down Converter with Full Differential Sense datasheet
PDF, 8.2 Мб, Версия: D, Файл опубликован: 7 июл 2017
Pin40
Package TypeRVF
Industry STD TermLQFN-CLIP
JEDEC CodeR-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаTPS548D22
Width (мм)5
Length (мм)7
Thickness (мм)1.46
Pitch (мм).5
Max Height (мм)1.52
Control ModeD-CAP3
Duty Cycle(Max)80 %
Iout(Max)40 A
Iq(Typ)2 мА
Package GroupLQFN-CLIP
Regulated Outputs1
Special FeaturesAdjustable Current Limit,Enable,Light Load Efficiency,Output Discharge,Power Good,Pre-Bias Start-Up,Remote Sense,Synchronous Rectification,UVLO Adjustable
Switching Frequency(Max)1050 kHz
Switching Frequency(Min)425 kHz
ТипConverter
Vin(Max)16 В
Vin(Min)1.5 В
Vout(Max)5.5 В
Vout(Min)0.6 В
  • Evaluation Modules & Boards: TPS548D22EVM-784
    TPS548D22 DCAP3 High Performance, 40-A Single Synchronous Step-Down Converter Evaluation Module
  • Calculating Output Capacitance to Meet Transient and Ripple Requirements
    PDF, 189 Кб, Файл опубликован: 2 май 2017
    This document provides guidance on how to calculate the amount of output capacitance needed to meet the transient and ripple requirements of a general buck converter design. DCAPx modulators are used in the example.
  • Accuracy-Enhanced Ramp-Generation Design for D-CAP3 Modulation (Rev. A)
    PDF, 493 Кб, Версия: A, Файл опубликован: 25 апр 2016
    D-CAP and D-CAP2 control schemes have been widely used in TI Switched-Mode DC-DC converters due to their fast transient response and no off-chip compensation. Offset generated by current sense ramp adds an error to VFB and Vout and hence reduces DC accuracy. This paper introduces a new D-CAP3 control scheme which greatly improves DC accuracy of the converter while maintaining the same fast transie
  • SMT Guidelines for Stacked Inductor (Inductor On Top) on Voltage Regulator IC
    PDF, 409 Кб, Файл опубликован: 22 фев 2016
Серия: TPS548D22 (2)
На английском языке: Datasheet Texas Instruments TPS548D22RVFT
