Datasheet Texas Instruments LDC0851HDSGR — Даташит
СерияLDC0851
МодельLDC0851HDSGR
Дифференциально компенсированный и высокоточный индуктивный переключатель 8-WSON от -40 до 125
LDC0851 Differential Inductive Switch datasheet
PDF, 2.5 Мб, Версия: A, Файл опубликован: 16 янв 2016
Package TypeDSG
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY3000
Маркировка0851
Width (мм)2
Length (мм)2
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
# Input Channels1
Analog Supply (V)3.3 Min
InterfacePush/Pull
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Pin/Package8WSON
Sensor Frequency300KHz to 19MHz Hz
  • Evaluation Modules & Boards: LDC0851EVM
    LDC0851EVM - High Accuracy Inductive Switch with Stacked Coils Evaluation Module
  • LDC0851 Quick-Start Guide
    PDF, 1.1 Мб, Файл опубликован: 16 мар 2016
  • LDC0851 - Troubleshooting
    PDF, 991 Кб, Файл опубликован: 3 янв 2017
  • Flowmeters Using Inductive Switches for Home Appliances
    PDF, 469 Кб, Файл опубликован: 27 июл 2017
  • Reliably Detect Faults In Circuit Breakers Using Contactless Inductive Switches
    PDF, 581 Кб, Файл опубликован: 20 мар 2017
    Circuit breakers are commonly used to manage theflow of electricity within a home or office but theirreliable functionality is often taken for granted. Circuitbreakers rely on making a solid electrical contactbetween the AC mains and the rest of the circuitry withthe ability the open the circuit in the case of a shortcircuit or power surge. While this is a very robustmethod towards m
  • EMI Considerations for Inductive Sensing
    PDF, 151 Кб, Файл опубликован: 22 фев 2017
    This application note explains various EMI reduction techniques to help improve EMI performance for TI'sInductance-to-Digital Converters (LDC). Each section details a general technique with references to otheruseful online documents. A list of relevant EMI reduction techniques is provided for specific devices withinthe LDC family of products.
  • LDC Device Selection Guide (Rev. B)
    PDF, 360 Кб, Версия: B, Файл опубликован: 21 мар 2017
  • LDC1xxx LDC Target Design (Rev. A)
    PDF, 907 Кб, Версия: A, Файл опубликован: 9 май 2017
    Texas Instruments’ Inductive-to-Digital Converter (LDC) technology can accurately measure with a wide variety of target sizes, shapes, and material composition. There are several target design guidelines to maximize the effectiveness of an LDC measurement system. This application note covers the relevant factors of target design that affect inductive sensing, and provides guide
  • Measuring Rp of an L-C Sensor for Inductive Sensing
    PDF, 205 Кб, Файл опубликован: 1 окт 2015
    When designing an application using TI’s LDC series of inductive sensors, it is necessary to know the L-C sensor’s equivalent parallel resistance RP at the sensor’s resonant frequency. The RP value changes as the target is moved; the minimum RP occurs when the metal target is closest to the sensor. The maximum RP occurs when the target is at the farthest distance. Accordingly, both values should b
Серия: LDC0851 (2)
  • Semiconductors > Sensing Products > Inductive Sensing > Inductive Touch
На английском языке: Datasheet Texas Instruments LDC0851HDSGR
