Datasheet Texas Instruments LM358AM/NOPB — Даташит
СерияLM358-N
МодельLM358AM/NOPB
Двойной операционный усилитель малой мощности 8-SOIC от 0 до 70
LMx58-N Low-Power, Dual-Operational Amplifiers datasheet
PDF, 1.9 Мб, Версия: I, Файл опубликован: 30 дек 2014
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9595
CarrierTUBETUBE
Маркировка358AMLM
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)65 дБ
CMRR(Typ)85 дБ
GBW(Typ)1 МГц
IIB(Max)100000 pA
Iq per channel(Max)0.6 мА
Iq per channel(Typ)0.25 мА
Количество каналов2
Offset Drift(Typ)7 uV/C
Output Current(Typ)20 мА
Rail-to-RailIn to V-
Slew Rate(Typ)0.1 V/us
Total Supply Voltage(Max)32 +5V=5, +/-5V=10
Total Supply Voltage(Min)3 +5V=5, +/-5V=10
Vn at 1kHz(Typ)40 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)3 мВ
  • AN-298 Isolation Techniques for Signal Conditioning (Rev. B)
    PDF, 685 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note provides information and examples of isolation techniques for signal conditioning.
  • Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)
    PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits.
  • AN-C V/F Converter ICs Handle Frequency-to-Voltage Needs (Rev. B)
    PDF, 371 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Simplify your frequency-to-voltage (F/V) converter designs with versatile V/F ICs. Starting with a basicconverter circuit you can modify it to meet almost any application requirement. You can spare yourselfsome hard labor when designing F/V converters by using a voltage-to-frequency (V/F) IC in your designs.These ICs form the basis of a series of accurate yet economical F/V converters sui
  • AN-116 Use the LM158/LM258/LM358 Dual Single Supply Op Amp (Rev. B)
    PDF, 313 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note discusses the use of the LM158/LM258/LM358 dual op amp when operated from asingle supply.
  • Using ADC0808/809 8-Bit uP Compble ADCs w/8-Chan Analog Multiplexr (Rev. B)
    PDF, 1.4 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application note discusses the use of the ADC0808/ADC0809 Data Acquisition Devices (DAD) withan 8-channel analog multiplexer.
  • AN-284 Single-Supply Applications of CMOS MICRODACs (Rev. B)
    PDF, 271 Кб, Версия: B, Файл опубликован: 22 апр 2013
    CMOS data acquisition and conversion products are becoming the ideal choice for microprocessorcontrolled analog systems. The use of CMOS allows the addition of more digital logic functionality on tothe same die as the analog circuitry to minimize external parts requirements. The inherently low powerconsumption is also a big factor for battery operation and low heat generation in large scale
  • Applications of the LM3524 Pulse Width Modulator (Rev. B)
    PDF, 549 Кб, Версия: B, Файл опубликован: 23 апр 2013
    The LM3524 regulating pulse-width-modulator (PWM) is commonly used as the control element inswitching regulator power supplies. This is in keeping with its intended purpose. Engineers closelyassociate this part with switching power supplies. Nevertheless, the flexible combination of elements (seebox) within the LM3524 also allows it to be used in a number of other applications outside the po
  • Semiconductors > Space & High Reliability > Amplifier > Operational Amplifiers
На английском языке: Datasheet Texas Instruments LM358AM/NOPB
