Оптопары и оптореле Megawin
Datasheet Texas Instruments THS4141IDGKR — Даташит
СерияTHS4141
МодельTHS4141IDGKR
Полностью дифференциальный усилитель ввода/вывода с высокой скоростью нарастания напряжения 8-VSSOP от -40 до 85
High-Speed Fully Differential I/O Amplifiers datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 31 янв 2006
Package TypeDGK
Industry STD TermVSSOP
МаркировкаASR
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
2nd Harmonic(dBc)83
3rd Harmonic(dBc)80
@ MHz1
Acl, min spec gain(V/V)1
Additional FeaturesN/A
Approx. Price (US$)6.77 | 100u
АрхитектураFully Differential
Voltage FB
BW @ Acl(MHz)160
CMRR(Min)(dB)75
CMRR(Typ)(dB)84
GBW(Typ)(MHz)170
Input Bias Current(Max)(pA)15000000
Iq per channel(Max)(mA)16
Iq per channel(Typ)(mA)13.2
Number of Channels(#)1
Offset Drift(Typ)(uV/C)7
Operating Temperature Range(C)-40 to 85
0 to 70
Output Current(Typ)(mA)85
Package GroupVSSOP
Package Size: mm2:W x L (PKG)8VSSOP: 15 mm2: 4.9 x 3(VSSOP)
Rail-to-RailNo
Slew Rate(Typ)(V/us)450
Total Supply Voltage(Max)(+5V=5, +/-5V=10)33
Total Supply Voltage(Min)(+5V=5, +/-5V=10)4
Vn at Flatband(Typ)(nV/rtHz)6.5
Vos (Offset Voltage @ 25C)(Max)(mV)7
RoHSНе совместим
  • Evaluation Modules & Boards: THS4140EVM
    THS4140EVM Evaluation Module
  • Fully-Differential Amplifiers (Rev. E)
    PDF, 867 Кб, Версия: E, Файл опубликован: 19 сен 2016
    Differential signaling has been commonly used in audio, data transmission, and telephone systems for many years because of its inherent resistance to external noise sources. Today, differential signaling is becoming popular in high-speed data acquisition, where the ADC’s inputs are differential and a differential amplifier is needed to properly drive them.Two other advantages of di
На английском языке: Datasheet Texas Instruments THS4141IDGKR
