Datasheet Texas Instruments LM317MKTPR — Даташит
СерияLM317M
МодельLM317MKTPR
LM317M 3-Terminal Adjustable Regulator datasheet
PDF, 1.1 Мб, Версия: P, Файл опубликован: 31 мар 2014
Pin2
Package TypeKTP
Industry STD TermPFM
JEDEC CodeR-PSFM-G
МаркировкаLM317M
Width (мм)6.15
Length (мм)6.04
Thickness (мм)1.91
Pitch (мм)4.57
Max Height (мм)2.03
Accuracy(%)4
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.26 | 1ku
Iout(Max)(A)0.5
Iq(Typ)(mA)3.5
Noise(uVrms)1110
Operating Temperature Range(C)-40 to 125
Output Capacitor TypeCap Free
Non-Ceramic
Output OptionsAdjustable Output
PSRR @ 100KHz(dB)22
Package GroupSOT-223
TO-252
Package Size: mm2:W x L (PKG)See datasheet (PFM)
Powered LoadFPGA
Microcontroller
Microprocessor
Regulated Outputs(#)1
Vdo(Typ)(mV)2000
Vin(Max)(V)40
Vin(Min)(V)3
Vout(Max)(V)37
Vout(Min)(V)1.2
RoHSНе совместим
  • AN-178 Applications for an Adjustable IC Power Regulator (Rev. B)
    PDF, 219 Кб, Версия: B, Файл опубликован: 5 май 2013
    This application report provides applications for the Texas Instruments LM117 3-terminal adjustableregulator.
  • High Stability Regulators
    PDF, 104 Кб, Файл опубликован: 3 окт 2002
  • AN-42 IC Provides On-Card Regulation for Logic Circuits (Rev. B)
    PDF, 593 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application report provides on-card regulation for logic circuits.
  • Adjustable 3-Terminal Regulator for Low-Cost Battery Charging Systems
  • High-Efficiency Reg has Low Drop-Out Voltage (Rev. B)
    PDF, 60 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Conventional regulators have a high drop-out voltage that is a function of the total output current.However with just a regulator chip an external transistor and a few passive components this designforms a high output current regulator with a limited input voltage and high efficiency. The circuit presentedhas a drop-out of 0.7V at 5A load current and 1.3V at a current level of as high as
  • A New Production Technique for Trimming Voltage Regulators
    PDF, 105 Кб, Файл опубликован: 3 окт 2002
  • AB-12 Wide Adjustable Range PNP Voltage Regulator (Rev. B)
    PDF, 47 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the PNP voltage regulator.
  • AN-182 Improving Power Supply Reliability with IC Power Regulators (Rev. B)
    PDF, 82 Кб, Версия: B, Файл опубликован: 5 май 2013
    This application report discusses improving power supply reliability with IC power regulators.
  • AN-181 3-Terminal Regulator is Adjustable (Rev. B)
    PDF, 314 Кб, Версия: B, Файл опубликован: 5 май 2013
    Until now all of the 3-terminal power IC voltage regulators have a fixed output voltage. In spite of this limitation their ease of use low cost and full on-chip overload protection have generated wide acceptance. Now with the introduction of the LM117 it is possible to use a single regulator for any output voltage from 1.2 V to 37 V at 1.5A. Selecting close-tolerance outp
  • AN-1061 Power Conversion in Line-Powered Equipment (Rev. B)
    PDF, 406 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note describes line-powered equipment and power conversion techniques or methods tosolve those typical power needs.
  • Method For Cal Output Voltage Tolerances in Adj Regs (Rev. A)
    PDF, 284 Кб, Версия: A, Файл опубликован: 5 май 2013
    When working with voltage regulator circuits the designer is often confronted with the need to calculatethe tolerance of the regulated output voltage. For fixed voltage regulators this problem is easily managedbecause the required information is directly supplied on the semiconductor manufacturer's data sheet.
  • AN-1148 Linear Regulators: Theory of Operation and Compensation (Rev. B)
    PDF, 300 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation and compensation of linear regulators.
На английском языке: Datasheet Texas Instruments LM317MKTPR
Публикации по теме
