Datasheet Texas Instruments LMP7704MT/NOPB — Даташит
Серия | LMP7704 |
Модель | LMP7704MT/NOPB |
Прецизионные усилители с КМОП-входом, RRIO, широкий диапазон питания 14-TSSOP от -40 до 125
LMP770x Precision, CMOS Input, RRIO, Wide Supply Range Amplifiers datasheet
PDF, 1.4 Мб, Версия: I, Файл опубликован: 30 ноя 2015
Pin | 14 | 14 |
Package Type | PW | PW |
Industry STD Term | TSSOP | TSSOP |
Package QTY | 94 | 94 |
Carrier | TUBE | TUBE |
Маркировка | 04MT | LMP77 |
Width (мм) | 4.4 | 4.4 |
Length (мм) | 5 | 5 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1.2 | 1.2 |
Additional Features | N/A |
Архитектура | CMOS |
CMRR(Min) | 88 дБ |
CMRR(Typ) | 130 дБ |
GBW(Typ) | 2.5 МГц |
Input Bias Current(Max) | 1 pA |
Iq per channel(Max) | 0.925 мА |
Iq per channel(Typ) | 0.725 мА |
Количество каналов | 4 |
Offset Drift(Typ) | 1 uV/C |
Output Current(Typ) | 66 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 1 V/us |
Total Supply Voltage(Max) | 12 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 9 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.22 мВ |
Бессвинцовая технология (Pb Free) | Да |
- AN-1559 Practical RTD Interface Solutions (Rev. B)PDF, 120 Кб, Версия: B, Файл опубликован: 1 май 2013
This application report is intended to review Resistance Temperature Devices (RTD) and commonly usedinterfaces for them. - AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
Серия: LMP7704 (5)
- LMP7704MA/NOPB LMP7704MAX/NOPB LMP7704MT LMP7704MT/NOPB LMP7704MTX/NOPB
