Datasheet Texas Instruments SN74AS151NSR — Даташит
СерияSN74AS151
МодельSN74AS151NSR
Селекторы/мультиплексоры данных 1 из 8 16-SO от 0 до 70
1-of-8 Data Selectors/Multiplexers datasheet
PDF, 734 Кб, Версия: A, Файл опубликован: 1 дек 1994
Pin16
Package TypeNS
Industry STD TermSOP
Package QTY2000
Маркировка74AS151
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
Полоса частот125 МГц
Bits8
Количество каналов1
Configuration8:1
Digital input leakage(Max)5 uA
ESD Charged Device Model0.75 kV
ESD HBM2 kV
F @ Nom Voltage(Max)125 Mhz
FunctionEncoder/Multiplexer
ICC @ Nom Voltage(Max)30 мА
Output Drive (IOL/IOH)(Max)48/-15 мА
Package GroupSO
Package Size: mm2:W x L16SO: 80 mm2: 7.8 x 10.2(SO) PKG
Schmitt TriggerNo
Technology FamilyAS
ТипStandard
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)24 нс
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
Серия: SN74AS151 (3)
  • Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
На английском языке: Datasheet Texas Instruments SN74AS151NSR
