Datasheet Texas Instruments DAC104S085CIMMX/NOPB — Даташит
СерияDAC104S085
МодельDAC104S085CIMMX/NOPB
10-битный цифро-аналоговый преобразователь Micro Power QUAD с выходом Rail-to-Rail 10-VSSOP от -40 до 105
DAC104S085-xx 10-Bit Micro Power QUAD Digital-to-Analog Converter With Rail-to-Rail Output datasheet
PDF, 1.4 Мб, Версия: G, Файл опубликован: 27 апр 2016
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
Package QTY3500
МаркировкаX68C
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
Code to Code Glitch(Typ)12 nV-sec
DAC ArchitectureString
DAC Channels4
Gain Error(Max)1 %FSR
INL(Max)2 +/-LSB
InterfaceSPI
Output Range Max.5.5 mA/V
Тип выходаBuffered Voltage
Package GroupVSSOP
Package Size: mm2:W x L10VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Power Consumption(Typ)1.1 mW
Reference: TypeExt
Разрешение10 Bits
Sample / Update Rate2.5 MSPS
Время установления6 µs
Special FeaturesN/A
Zero Code Error(Typ)15 мВ
  • AN-2001 Daisy Chaining Precision DACs (Rev. A)
    PDF, 75 Кб, Версия: A, Файл опубликован: 1 май 2013
    It is not uncommon for the system designer to face a quagmire of reconciling the system complexity withthe desire to keep the system footprint small. One specific example that often arises in the context ofsmall system footprint is the need for single master controller to communicate with a number of slavedevices. This is not much of a problem if the master controller has multiple I/O resour
На английском языке: Datasheet Texas Instruments DAC104S085CIMMX/NOPB
