Datasheet Texas Instruments LM86CIMX/NOPB — Даташит
СерияLM86
МодельLM86CIMX/NOPB
В±0.75В°C Remote and Local Temperature Sensor with SMBus Interface 8-SOIC 0 to 125
0.75C Accurate, Remote Diode & Local Digital Temp Sensor w/Two-Wire Interface datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 22 мар 2013
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаCIMLM86
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
InterfaceI2C,SMBus
Local Sensor Accuracy(Max)3 +/- C
Рабочий диапазон температурот 0 до 125 C
Remote Channel1
Remote Diode Temp Range for Listed Accuracy80 C
Remote Sensor Accuracy(Max)0.75 +/- C
Remote Sensor CorrectionOffset Correction Register
Remote Temp Resolution(Max)11 bits
Special FeaturesProgrammable Alert,Programmable conversion rate,Shutdown
Supply Current(Typ)800 uA
Supply Voltage(Max)3.6 В
Supply Voltage(Min)3 В
Temp Resolution(Max)8 bits
  • Semiconductors > Sensing Products > Temperature Sensors > Remote / Multi-channel Temperature Sensors
На английском языке: Datasheet Texas Instruments LM86CIMX/NOPB
