Datasheet Texas Instruments TPS79628DRBR — Даташит
СерияTPS796
МодельTPS79628DRBR
Сверхмалошумящие, с высоким PSRR, быстрые, ВЧ, 1-А, линейные линейные стабилизаторы с низким падением напряжения 8-SON от -40 до 85
TPS796xx Ultralow-Noise, High PSRR, Fast, RF, 1-A Low-Dropout Linear Regulators datasheet
PDF, 1.5 Мб, Версия: P, Файл опубликован: 11 авг 2014
21 предложений от 15 поставщиков
Чип стабилизации напряжения, Single Channel LDO Single Output LDO, 1A, Fixed(2.8V), Low Noise, High PSRR LDO Regulator Pos 2.8V 1A 8Pin...
TPS79628DRBR
от 235 ₽
Hi-Tech Circuit Group
TPS79628DRBR
TPS79628DRBR
727GS
TPS79628DRBR
Package TypeDRB
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаAMI
Width (мм)3
Length (мм)3
Thickness (мм).88
Max Height (мм)1
Accuracy(%)2
Additional FeaturesEnable
Overcurrent Protection
Thermal Shutdown
Approx. Price (US$)1.10 | 1ku
Fixed Output Options(V)1.3
1.8
2.5
2.8
3
3.3
5
Iout(Max)(A)1
Iq(Typ)(mA)0.26
Noise(uVrms)42
Operating Temperature Range(C)-40 to 125
-40 to 85
Output Capacitor TypeCeramic
Output OptionsAdjustable Output
Fixed Output
PSRR @ 100KHz(dB)42
Package GroupSON
Package Size: mm2:W x L (PKG)See datasheet (SON)
Regulated Outputs(#)1
Vdo(Typ)(mV)220
Vin(Max)(V)5.5
Vin(Min)(V)2.7
Vout(Max)(V)5.4
Vout(Min)(V)1.2
  • Evaluation Modules & Boards: TPS79601DRBEVM
    Evaluation Module for TPS79601 Single Output LDO
  • Evaluation Modules & Boards: TPS78633EVM-207
    TPS78633 Evaluation Module
  • Evaluation Modules & Boards: DEM-SOT223LDO
    DEM-SOT223LDO Compatible with Most Positive Output LDOs in SOT223 (DCQ) Package
  • Evaluation Modules & Boards: EVMK2G
    66AK2Gx (K2G) Evaluation Module
  • Monotonic, Inrush Current Limited Start-Up for Linear Regulators
    PDF, 268 Кб, Файл опубликован: 22 мар 2004
    The output voltage of a linear regulator tends to rise quickly after it is enabled. This often results in the nonmonotonic rise of the output voltage (i.e., the output voltage overshoots, then dips), which can preclude proper operation of the load circuitry. This application report addresses methods to achieve a monotonic, inrush current limited start-up.
  • Powering today’s multi-rail FPGAs and DSPs, Part 2
    PDF, 307 Кб, Файл опубликован: 18 апр 2006
  • Q1 2010 Issue Analog Applications Journal
    PDF, 2.6 Мб, Файл опубликован: 29 янв 2010
На английском языке: Datasheet Texas Instruments TPS79628DRBR
