Datasheet Texas Instruments OPA622AU — Даташит
СерияOPA622
МодельOPA622AU
Wide-Bandwidth Operational Amplifier
PDF, 354 Кб, Файл опубликован: 14 фев 2001
Рекомендуемая замена
ReplacementOPA658U
Replacement CodeF
RoHSНе совместим
  • Current or Voltage Feedback/New, Flexible,Wide-Band Operational Amplifier OPA622
    PDF, 108 Кб, Файл опубликован: 2 окт 2000
    This application note will present the internal circuit configuration, specifications, and frequency response alignment of the OPA622 and will also describe its diverse applications.
  • Intermodulation Distortion (IMD)
    PDF, 82 Кб, Файл опубликован: 2 окт 2000
    The intermodulation distortion (IMD) performance of wideband, DC-coupled amplifiers is a relatively new area for integrated operational amplifier suppliers. New progresses in IC technology extend the application of op amps where some years ago discrete circuits played the major role. Methods to measure and communicate the extent of this distortion to users have been borrowed from traditional RF
  • Macromodels for RF Op Amps Are a Powerful Design Tool
    PDF, 68 Кб, Файл опубликован: 2 окт 2000
    The macromodel for the Diamond Transistor OPA660 gives an example of the structure and performance of these new Spice models.
Серия: OPA622 (3)
На английском языке: Datasheet Texas Instruments OPA622AU
