Datasheet Texas Instruments DAC128S085CIMTX/NOPB — Даташит
СерияDAC128S085
МодельDAC128S085CIMTX/NOPB
12-битный восьмеричный цифро-аналоговый преобразователь Micro Power с выходами Rail-to-Rail 16-TSSOP от -40 до 125
DAC128S085 12-Bit Micro-Power OCTAL Digital-to-Analog Converter With Rail-to-Rail Outputs datasheet
PDF, 1.4 Мб, Версия: H, Файл опубликован: 6 апр 2015
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2500
МаркировкаX78C
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Code to Code Glitch(Typ)40 nV-sec
DAC ArchitectureString
DAC Channels8
Gain Error(Max)1 %FSR
INL(Max)8 +/-LSB
InterfaceSPI
Output Range Max.5.5 mA/V
Тип выходаBuffered Voltage
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Power Consumption(Typ)1.95 mW
Reference: TypeExt
Разрешение12 Bits
Sample / Update Rate2.5 MSPS
Время установления8.5 µs
Special FeaturesSDO
Zero Code Error(Typ)15 мВ
  • Evaluation Modules & Boards: DAC128S085EB
    DAC128S085EB Evaluation Board
  • Evaluation Modules & Boards: DAC128S085EVM
    12-bit 8 Channel Digital to Analog Converter Evaluation Module
  • AN-2001 Daisy Chaining Precision DACs (Rev. A)
    PDF, 75 Кб, Версия: A, Файл опубликован: 1 май 2013
    It is not uncommon for the system designer to face a quagmire of reconciling the system complexity withthe desire to keep the system footprint small. One specific example that often arises in the context ofsmall system footprint is the need for single master controller to communicate with a number of slavedevices. This is not much of a problem if the master controller has multiple I/O resour
На английском языке: Datasheet Texas Instruments DAC128S085CIMTX/NOPB
