Datasheet Texas Instruments INA114BPG4 — Даташит
СерияINA114
МодельINA114BPG4
Прецизионный инструментальный усилитель 8-PDIP
Precision Instrumentation Amplifier datasheet
PDF, 749 Кб, Файл опубликован: 27 сен 2000
14 предложений от 14 поставщиков
IC INST AMP 1 CIRCUIT 8DIP. Instrumentation Amplifier 1 Circuit 8-PDIP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps
INA114BPG4
859 ₽
INA114BPG4
982 ₽
INA114BPG4
INA114BPG4
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаINA114BP
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Bandwidth at Min Gain(Typ)1 МГц
CMRR(Min)110 дБ
Gain Error (+/-)(Max)2 %
Gain Non-Linearity (+/-)(Max)0.002 %
Gain(Max)10000 V/V
Gain(Min)1 V/V
Input Bias Current (+/-)(Max)2 нА
Input Offset (+/-)(Max)50 uV
Input Offset Drift (+/-)(Max)0.25 uV/C
Iq(Typ)2.2 мА
Noise at 0.1 Hz - 10 Hz(Typ)0.4 uVpp
Noise at 1kHz(Typ)(nV/rt11 Hz
Количество каналов1
Package GroupPDIP
Vs(Max)36 В
Vs(Min)4.5 В
  • Use Low-Impedance Bridges on 4-20mA Current Loop
    PDF, 27 Кб, Файл опубликован: 27 сен 2000
    If you need more transducer excitation current than is available on a standard 4-20mA 2-wire current loop, consider a 3-wire transmitter. A 2-wire 4-20mA transmitter uses the same two wires for signal and power. Part of the 4mA minimum loop current is used to power the transmitter circuitry. The remaining current can be used for transducer excitation. In some applications even the entire 4mA is no
  • Semiconductors > Amplifiers > Instrumentation Amplifiers
На английском языке: Datasheet Texas Instruments INA114BPG4
