Datasheet Texas Instruments UC1861J883B — Даташит
СерияUC1861
МодельUC1861J883B
Резонансные контроллеры блоков питания 16-CDIP от -55 до 125
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • U-138 Zero Voltage Switching Resonant Power Conversion
    PDF, 794 Кб, Файл опубликован: 5 сен 1999
    This application note explores the technique of zero voltage switching in modern power conversion. It describes several ZVS topologies and applications limitations of the ZVS technique and a generalized design procedure. Two design examples are presented: a 50W DC/DC converter and an off-line 300W multiple output power supply. This discussion concludes with a performance comparison of ZVS conve
  • U-122 A New Family of Integrated Circuits Controls Resonant Mode Power
    PDF, 272 Кб, Файл опубликован: 5 сен 1999
    This application note introduces the UC3861-8 family of ICs which are optimized for the control of zero-current-switched and zero-voltage-switched quasi-resonant converters. Differences among members of this device family result from the various combinations of UVLO thresholds and output options. The one-shot pulse steering logic is configured to program either on time for ZCS systems (UC1865-186
Серия: UC1861 (2)
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC1861J883B
