Datasheet Texas Instruments F28M35H22C1RFPQ — Даташит
СерияF28M35H22C
МодельF28M35H22C1RFPQ
Концертный микроконтроллер 144-HTQFP от -40 до 125
F28M35x Concerto Microcontrollers datasheet
PDF, 2.2 Мб, Версия: I, Файл опубликован: 8 июн 2015
Pin144
Package TypeRFP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY60
МаркировкаF28M35H22C1RFPQ
Width (мм)20
Length (мм)20
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
# of ADC Modules2
12-bit A/D (#Channels)20
ADC Channels20
ADC Conversion Time(ns)172
ADC Resolution12-bit
ADC Sample & HoldDual
Approx. Price (US$)14.75 | 1ku
CAN(#)2
CAP/QEP6 / 3
CPUC28x
Cortex-M3
DMA(Ch)1 6-Ch DMA
1 32-ch DMA
EMIFYes
Ethernet1
FPUYes
Flash(KB)512
Frequency(MHz)150
100
GPIO64
Generation28x + ARM Cortex M3 Concerto Series
I2C3
IO Supply(V)3.3
McBSP1
Operating Temperature Range(C)-40 to 105
-40 to 125
PWM(Ch)24
Package GroupHTQFP
Package Size: mm2:W x L (PKG)144HTQFP: 484 mm2: 22 x 22(HTQFP)
RAM(KB)136
RISC Frequency(MHz)75
100
SPI5
Timers3 32-Bit CPU
1 WD
Total On-Chip Memory (KB)648
Total Serial Ports2 CANs
3 I2C
5 SPI
6 SCIs
1 McBSP
1 USB
1 Ethernet
UART6
USB1
RoHSНе совместим
  • Evaluation Modules & Boards: TMDSDOCKH52C1
    H52C1 Concerto Experimenter Kit
  • Evaluation Modules & Boards: TMDSSOLARCEXPKIT
    Concerto-based Solar Explorer Development Kit
  • Daughter Cards: TMDSCNCDH52C1
    H52C1 Concerto controlCARD
  • Evaluation Modules & Boards: TMDSHV1PHINVKIT
    High Voltage Single Phase Inverter Development Kit
  • JTAG Emulators/ Analyzers: C2000-GANG
    C2000 Gang Programmer
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • Calculating Useful Lifetimes of Embedded Processors
    PDF, 521 Кб, Файл опубликован: 11 ноя 2014
    This application report provides a methodology for calculating the useful lifetime of TI embedded processors (EP) under power when used in electronic systems. It is aimed at general engineers who wish to determine if the reliability of the TI EP meets the end system reliability requirement.
  • Calculator for CAN Bit Timing Parameters
    PDF, 37 Кб, Файл опубликован: 22 мар 2016
    Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat
Серия: F28M35H22C (3)
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Control + Automation > F28M3x
На английском языке: Datasheet Texas Instruments F28M35H22C1RFPQ
