Datasheet Texas Instruments ADS1000A0IDBVTG4 — Даташит
СерияADS1000
МодельADS1000A0IDBVTG4
12-разрядный, 128SPS, 1-канальный дельта-сигма АЦП с PGA, генератором и I2C 6-SOT-23 от -40 до 125
Low Power, 12-Bit Analog-to-Digital Converter datasheet
PDF, 627 Кб, Версия: A, Файл опубликован: 11 окт 2007
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаBD0
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
# Input Channels1
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураDelta-Sigma
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)1 +/-LSB
Input Range(Max)5.5 В
Тип входаDifferential,Single-Ended
Integrated FeaturesOscillator,PGA
InterfaceI2C
Multi-Channel ConfigurationN/A
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Power Consumption(Typ)0.21 mW
Reference ModeSupply
Разрешение12 Bits
Sample Rate (max)128SPS SPS
Sample Rate(Max)0.000128 MSPS
  • Digital Filter Types in Delta-Sigma ADCs
    PDF, 219 Кб, Файл опубликован: 27 июн 2017
    This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS1000A0IDBVTG4
