Клеммники KEEN SIDE
Datasheet Texas Instruments TPA1517DWPRG4 — Даташит
СерияTPA1517
МодельTPA1517DWPRG4
Стерео, аудиоусилитель средней мощности класса AB 20-SO PowerPAD от -40 до 85
6-W Stereo Audio Power Amplifier datasheet
PDF, 922 Кб, Версия: D, Файл опубликован: 20 фев 2007
Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS TPA1517DWPRG4 Audio Power Amplifier, AB, 2Channel, 6W, 9.5V to 18V, SOIC, 20Pins
TPA1517DWPRG4
74 ₽
Рутоника
TPA1517DWPRG4
137 ₽
TPA1517DWPRG4
178 ₽
TPA1517DWPRG4
179 ₽
Pin20
Package TypeDWP
Industry STD TermHSOIC
Package QTY2000
МаркировкаTPA1517
Width (мм)7.52
Length (мм)12.82
Thickness (мм)2.55
Max Height (мм)2.65
Analog Supply (V)9.5 Max
Audio Input TypeAnalog
Closed/Open LoopOpen
Control InterfaceHardware
Package GroupSO PowerPAD
Package Size: mm2:W x L20SO PowerPAD: 133 mm2: 10.405 x 12.825(SO PowerPAD) PKG
Power Stage Supply(Max)18 В
Power Stage Supply(Min)9.5 В
Speaker Channels2 Max
  • Evaluation Modules & Boards: TPA1517DWPEVM
    TPA1517DWP Evaluation Module (EVM)
  • Reducing And Eliminating The Class-D Output Filter
    PDF, 180 Кб, Файл опубликован: 24 авг 1999
    This application report investigates reducing and eliminating the LC output filter traditionally used in class-D audio power amplifier applications. The filter can be completely eliminated if the designer is using a predominatly inductive speaker; however, the supply current and the EMI are higher than if using the full second-order Butterworth low-pass filter. The designer can use half of the com
  • Design Considerations For Class-D Audio Power Amplifiers
    PDF, 144 Кб, Файл опубликован: 23 авг 1999
    This application report provides background information, general equations, and component selection criteria for proper design and implementation of the Texas Instruments class-D audio power amplifiers. Topics include class-D switching and charge pump circuits, signal conditioning of the audio inputs and outputs for both the class-D and class-AB headphone amplifiers, IC Control and indicator circu
  • Pop Reduction for the TPA1517 Audio Power Amplifier
    PDF, 228 Кб, Файл опубликован: 31 авг 2004
  • RC Filter Box For Class-D Output Power and THD+N Measurement
    PDF, 636 Кб, Файл опубликован: 20 фев 2004
  • Measuring Class-D Amplifiers for Audio Speaker Overstress Testing
    PDF, 175 Кб, Файл опубликован: 28 окт 2005
    This application report presents the results of an experiment conducted to demonstrate how to address the two most common concerns regarding speaker damage using Class-D amplifiers.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
  • PowerPAD Thermally Enhanced Package (Rev. H)
    PDF, 983 Кб, Версия: H, Файл опубликован: 6 июл 2018
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TPA1517DWPRG4
