Datasheet Texas Instruments LM70CIMMX-3/NOPB — Даташит
СерияLM70
МодельLM70CIMMX-3/NOPB
В±2В°CВ  Temperature Sensor with SPI Interface 8-VSSOP -55 to 150
LM70 SPI/MICROWIRE 10-Bit plus Sign Digital Temperature Sensor datasheet
PDF, 1.2 Мб, Версия: G, Файл опубликован: 22 мар 2013
Package TypeDGK
Industry STD TermVSSOP
Package QTY3500
МаркировкаT04C
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
AddressesNA
InterfaceSPI, Microwire
Iq(Typ)260 uA
Local Sensor Accuracy(Max)2 +/- C
Рабочий диапазон температурот -55 до 150 C
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Special FeaturesShutdown
Supply Current(Max)490 uA
Supply Current(Typ)260 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)2.65 В
Temp Resolution(Max)11 bits
  • Tiny Temperature Sensors for Remote Systems
    PDF, 156 Кб, Файл опубликован: 17 фев 2003
  • AN-1256 Tiny Temperature Sensors for Portable Systems (Rev. A)
    PDF, 77 Кб, Версия: A, Файл опубликован: 26 апр 2013
    The last year has seen the introduction of silicon temperature sensors in revolutionary small packages,ideal for portable systems. This application report discusses trade-offs in accuracy, as well as how tochoose between thermistors and analog output IC temperature sensors.
  • Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
LM70CIMMX3/NOPB, LM70CIMMX 3/NOPB
На английском языке: Datasheet Texas Instruments LM70CIMMX-3/NOPB
