Datasheet Texas Instruments MC34063ADRE4 — Даташит
СерияMC34063A
МодельMC34063ADRE4
Повышающий/понижающий/инвертирующий импульсный стабилизатор 1,5 А 8-SOIC 0–70
MC3x063A 1.5-A Peak Boost/Buck/Inverting Switching Regulators datasheet
PDF, 1.3 Мб, Версия: N, Файл опубликован: 29 янв 2015
Преобразователь DC/DC, Conv DC-DC 3V to 40V Inv/Step Up/Step Down Single-Out 1.25V to 40V 1.5A 8Pin SOIC T/R
MC34063ADRE4
14 ₽
MC34063ADRE4
17 ₽
MC34063ADRE4
26 ₽
ТаймЧипс
MC34063ADRE4
Package TypeD
Package QTY2500
МаркировкаM34063A
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Duty Cycle(Max)80 %
Iq(Typ)4 мА
Special FeaturesN/A
Switch Current Limit(Min)1.5 A
Switch Current Limit(Typ)1.5 A
Switching Frequency(Max)100 kHz
TopologyBoost,Buck,Flyback,Forward,Inverting,SEPIC
ТипConverter
Vin(Max)40 В
Vin(Min)3 В
Vout(Max)40 В
Vout(Min)1.25 В
  • Application of the MC34063 Switching Regulator (Rev. B)
    PDF, 169 Кб, Версия: B, Файл опубликован: 6 ноя 2007
    This application report provides the features that are necessary to implement dc-to-dc fixed-frequency schemes with a minimum number of external components using the MC34063. This device represents significant advancements in ease of use with highly efficient and, yet, simple switching regulators. The use of switching regulator is becoming more pronounced over that of linear regulators, because of
  • Adding shutdown feature to MC33063A, MC34063A switching regulators
    PDF, 228 Кб, Файл опубликован: 5 фев 2013
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost, Inverting or Split-Rail Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments MC34063ADRE4
