Datasheet Texas Instruments OPA2634U/2K5 — Даташит
Серия | OPA2634 |
Модель | OPA2634U/2K5 |
SpeedPlus(TM) Двойной широкополосный операционный усилитель с однополярным питанием 8-SOIC
Datasheet
![]() 11 предложений от 11 поставщиков Микросхема Операционный усилитель, SpeedPlus(TM) Dual, Wideband, Single-Supply Operational Amplifier 8-SOIC | |||
OPA2634U/2K5 | 142 ₽ | ||
OPA2634U/2K5 | 313 ₽ | ||
OPA2634U/2K5 Texas Instruments | 366 ₽ | ||
OPA2634U/2K5 | по запросу |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
RoHS | Не совместим |
- Evaluation Modules & Boards: DEM-OPA268XU
DEM-OPA268xU: Demonstration Fixture
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2634 (2)
- OPA2634U OPA2634U/2K5
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
