Datasheet Texas Instruments TPS548A20RVET — Даташит
Серия | TPS548A20 |
Модель | TPS548A20RVET |
Входное напряжение от 4,5 до 25 В, режим DCAP3, синхронный понижающий преобразователь SWIFT™, ток 15 А, 28-VQFN-CLIP от -40 до 125
TPS548A20 1.5-V to 20-V (4.5-V to 25-V Bias) Input, 15-A Synchronous Step-Down SWIFTв„ў Converter datasheet
PDF, 2.2 Мб, Версия: A, Файл опубликован: 2 дек 2015
Pin | 28 |
Package Type | RVE |
Industry STD Term | VQFN-CLIP |
JEDEC Code | R-PQFP-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | T548A20 |
Width (мм) | 3.5 |
Length (мм) | 4.5 |
Thickness (мм) | .9 |
Pitch (мм) | .4 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Control Mode | D-CAP3 |
Duty Cycle(Max) | 50 % |
Iout(Max) | 15 A |
Iq(Typ) | 1.35 мА |
Package Group | VQFN-CLIP |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Adjustable Current Limit,Enable,Light Load Efficiency,Power Good,Pre-Bias Start-Up,Synchronous Rectification |
Switching Frequency(Max) | 1000 kHz |
Switching Frequency(Min) | 250 kHz |
Тип | Converter |
Vin(Max) | 20 В |
Vin(Min) | 4.5 В |
Vout(Max) | 5.5 В |
Vout(Min) | 0.6 В |
Бессвинцовая технология (Pb Free) | Да |
- Evaluation Modules & Boards: TPS548A20EVM-737
TPS548A20 DCAP3 High Efficiency 15A Synchronous Buck Converter Evaluation Module
- Accuracy-Enhanced Ramp-Generation Design for D-CAP3 Modulation (Rev. A)PDF, 493 Кб, Версия: A, Файл опубликован: 25 апр 2016
D-CAP and D-CAP2 control schemes have been widely used in TI Switched-Mode DC-DC converters due to their fast transient response and no off-chip compensation. Offset generated by current sense ramp adds an error to VFB and Vout and hence reduces DC accuracy. This paper introduces a new D-CAP3 control scheme which greatly improves DC accuracy of the converter while maintaining the same fast transie - SMT Guidelines for Stacked Inductor (Inductor On Top) on Voltage Regulator ICPDF, 409 Кб, Файл опубликован: 22 фев 2016
Серия: TPS548A20 (2)
- TPS548A20RVER TPS548A20RVET
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
