Datasheet Texas Instruments TMS320DM355DZCEA21 — Даташит
СерияTMS320DM355
МодельTMS320DM355DZCEA21
Цифровая мультимедийная система на кристалле (DMSoC) 337-NFBGA от -40 до 100
TMS320DM355 Digital Media System-on-Chip (DMSoC) datasheet
PDF, 1.2 Мб, Версия: G, Файл опубликован: 24 июн 2010
Pin337337
Package TypeZCEZCE
Industry STD TermNFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-N
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаDM355DZCE A216TMS320
Width (мм)1313
Length (мм)1313
Thickness (мм).89.89
Pitch (мм).65.65
Max Height (мм)1.31.3
  • Development Kits: TMDSEVM355
    TMS320DM355 Digital Video Evaluation Module
    Статус продукта: NRND (Не рекомендуется для новых разработок)
    XDS200 USB Debug Probe
  • Implementing DDR2/mDDR PCB Layout on the TMS320DM35x DMSoC (Rev. D)
    PDF, 127 Кб, Версия: D, Файл опубликован: 11 ноя 2009
    the TMS320DM35x Digital Media System-on-Chip (DMSoC) device. The approach to specifying interface timing for the DDR2/mDDR interface is quite different than on previous devices.The previous approach specified device timing in terms of data sheet specifications and simulation models. The system designer was required to obtain compatible memory devices, as well as the device-specific data sheet
  • TMS320DM355 Power Consumption for Common Application Usage Scenarios (Rev. A)
    PDF, 53 Кб, Версия: A, Файл опубликован: 16 июл 2010
    This document discusses the power consumption for common system application usage scenarios for the TMS320DM355 digital media system-on-chip (DMSoC) processor. Power consumption is highly dependent on the individual user's application; however, this document focuses on providing several DM355 application-usage case scenarios and the environment settings that were used to perform such power measure
  • TMS320DM355/335 Migration Guide (Silicon revision 1.1, 1.3 and 1.4) (Rev. B)
    PDF, 75 Кб, Версия: B, Файл опубликован: 5 янв 2011
    This application report describes the differences between Silicon revision 1.1, 1.3 and 1.4 of the TMS320DM355/DM335 digital media system-on-chip (DMSoC). This document discusses behavior different from that described in the TMS320DM355 Digital Media System-on-Chip (DMSoC) ARM Subsystem User's Guide (SPRUFB3) and the TMS320DM335 Digital Med
  • Powering the TMS320DM335 and TMS320DM355 with the TPS650061
    PDF, 144 Кб, Файл опубликован: 13 окт 2011
    TPS650061, TMS320DM335, TMS320DM355 Powering the DM335 and DM355 with the TPS650061
  • Migrating From TMS320DM35x to TMS320DM36x Devices (Rev. A)
    PDF, 79 Кб, Версия: A, Файл опубликован: 2 июн 2011
    For purposes of comparison, this application report describes the key features of the TMS320DM36x (DM36x) and the TMS320DM35x (DM35x) digital media processors.
  • TMS320DM355 DSP Power Reference Design PR742 (Rev. A)
    PDF, 199 Кб, Версия: A, Файл опубликован: 8 авг 2008
    This reference design is for the TMS320DM335/DM355 digital signal processor (DSP) and accounts for voltage, current, and sequencing requirements. The operating input voltage ranges from 2 V to 5.5 V for Li-ion batteries and 3 AA batteries. This design also can work with 2 AA batteries with some limitations. The design is optimized for efficiency over the full range of operation and low overall cos
  • USB Compliance Checklist (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 10 мар 2010
  • Building a Small Embedded Linux Kernel Example (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 27 май 2008
    Building a Small Embedded Linux Kernel Example Application Report
  • LSP 2.10 DaVinci Linux Drivers (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 8 июл 2009
  • EDMA v2.0 to EDMA v3.0 (EDMA3) Migration Guide (Rev. A)
    PDF, 292 Кб, Версия: A, Файл опубликован: 21 авг 2008
    This application report summarizes the key differences between the enhanced direct memory access (EDMA3) used on C64x+в„ў DSP devices and the EDMA2 used on TMS320C64xв„ў DSP devices, and provides guidance for migrating from EDMA2 to EDMA3.
  • Understanding TI's PCB Routing Rule-Based DDR Timing Specification (Rev. A)
    PDF, 93 Кб, Версия: A, Файл опубликован: 17 июл 2008
    This application report motivates the way the DDR high-speed timing requirements are now going to be communicated to system designers. The traditional method of using data sheet parameters and simulation models is tedious. The system designer uses this information to evaluate whether timing specifications are met and can be expected to operate reliably.Ultimately, the real question the hardwa
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Digital Signal Processors > Media Processors > Digital Video Processors
На английском языке: Datasheet Texas Instruments TMS320DM355DZCEA21
