Оптопары и оптореле Megawin
Datasheet Texas Instruments ADS7809PB — Даташит
СерияADS7809
МодельADS7809PB
16-битный 10мкс последовательный КМОП аналого-цифровой преобразователь с дискретизацией 20-PDIP
16-Bit 10µs Serial CMOS Sampling Analog-to-Digital Converter datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 29 сен 2006
Pin20
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)24.33
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • Evaluation Modules & Boards: ADS7809EVM
    ADS7809EVM Evaluation Module
  • Dynamic Tests for A/D Converter Performance (Rev. A)
    PDF, 249 Кб, Версия: A, Файл опубликован: 18 май 2015
  • Upgrading From ADS7808/09 to ADS8508/09 Devices
    PDF, 66 Кб, Файл опубликован: 12 июн 2007
    The information contained in this document applies to current applications using the ADS7808 or ADS7809 in a surface-mount SOIC (DW) package.This document is a guide to users of the ADS7808/09 devices with regards to potential compatibility issues when upgrading to the new ADS8508 and ADS8509 series of devices.
  • ADS7809 Tag Features
    PDF, 50 Кб, Файл опубликован: 27 сен 2000
    The ADS7809 is part of a family of capacitive redistribution SAR A/D converters that feature a serial output and a tag pin for cascading multiple converters. Other members of this family include the ADS7806, ADS7807, ADS7808, ADS7824, and ADS7825. Note that the even numbered converters are 12-bit converters and the odd numbered converters are 16-bit converters.
  • Tips for Using the ADS78xx Family of A/D Converters
    PDF, 24 Кб, Файл опубликован: 27 сен 2000
    The input to each of the members of the ADS Family (ADS7804/05/06/07/08/09/10/19, so far) is a resistor divider network, converting the input signal to the range used internally. This resistor divider offers inherent overvoltage protection, which will often simplify analog circuitry.
  • Coding Schemes Used with Data Converters (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 15 май 2015
  • Interleaving Analog-to-Digital Converters
    PDF, 64 Кб, Файл опубликован: 2 окт 2000
    It is tempting when pushing the limits of analog-to-digital conversion to consider interleaving two or more converters to increase the sample rate. However, such designs must take into consideration several possible sources of error.
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • What Designers Should Know About Data Converter Drift
    PDF, 95 Кб, Файл опубликован: 2 окт 2000
    Exactly how inaccurate will a change in temperature make an analog-to-digital or digital-to-analog converter? As designers are well aware, a 12-bit device may provide a much lower accuracy at its operating-temperature extremes, perhaps only to 9 or even 8 bits. But for lack of more precise knowledge, many play it safe (and expensive) and overspecify.
  • Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
На английском языке: Datasheet Texas Instruments ADS7809PB
