Datasheet Texas Instruments TL497AIJ — Даташит
| Серия | TL497A |
| Модель | TL497AIJ |
500 мА пиковый повышающий, понижающий, инвертирующий импульсный стабилизатор напряжения 14-CDIP
| TL497AIJ | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 14 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Width (мм) | 6.67 |
| Length (мм) | 19.56 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Approx. Price (US$) | 0.57 | 1ku |
| Iq(Typ)(mA) | 11 |
| Operating Temperature Range(C) | -40 to 85 0 to 70 |
| Package Group | PDIP SO SOIC TSSOP |
| Rating | Catalog |
| Special Features | Enable |
| Switch Current Limit(Min)(A) | 0.5 |
| Switch Current Limit(Typ)(A) | 0.5 |
| Switching Frequency(Max)(kHz) | 50 |
| Topology | Inverting |
| Тип | Converter |
| Vin(Max)(V) | 12 |
| Vin(Min)(V) | 4.5 |
| Vout(Max)(V) | 30 |
| Vout(Min)(V) | -25 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Designing Switching Voltage Regulators with TL497APDF, 945 Кб, Файл опубликован: 11 авг 2003
Switching voltage regulators, represented by the TL497, can achieve high-efficiency power conversion at large input/output voltage differentials. The TL497A eliminates complex circuit designs previously required and provides greater efficiency than systems using series pass regulators. The principle of operation is discussed, and practical design exercises for step-down, step-up, and inverting reg - Understanding Buck Power Stages In Switchmode Power SuppliesPDF, 173 Кб, Файл опубликован: 4 мар 1999
A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous - Understanding Boost Power Stages In Switchmode Power SuppliesPDF, 149 Кб, Файл опубликован: 4 мар 1999
A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o - Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: TL497A (14)
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost, Inverting or Split-Rail Converter (Integrated Switch)
