Оптопары и оптореле Megawin
Datasheet Texas Instruments MC1458CP1 — Даташит
СерияLM1458
МодельMC1458CP1
Двойной операционный усилитель 8-PDIP от 0 до 70
LM1458/LM1558 Dual Operational Amplifier datasheet
PDF, 837 Кб, Версия: D, Файл опубликован: 27 мар 2013
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
МаркировкаLM1458N
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Рекомендуемая замена
ReplacementLM1458N/NOPB
Replacement CodeS
Additional FeaturesN/A
Approx. Price (US$)0.31 | 1ku
АрхитектураBipolar
CMRR(Min)(dB)70
CMRR(Typ)(dB)90
GBW(Typ)(MHz)1
Input Bias Current(Max)(pA)500000
Iq per channel(Max)(mA)2.8
Iq per channel(Typ)(mA)1.5
Number of Channels(#)2
Operating Temperature Range(C)-40 to 85
0 to 70
Output Current(Typ)(mA)45
Package GroupPDIP
Rail-to-RailNo
Slew Rate(Typ)(V/us)0.5
Total Supply Voltage(Max)(+5V=5, +/-5V=10)36
Total Supply Voltage(Min)(+5V=5, +/-5V=10)6
Vn at 1kHz(Typ)(nV/rtHz)30
Vos (Offset Voltage @ 25C)(Max)(mV)6
RoHSНе совместим
  • AN-116 Use the LM158/LM258/LM358 Dual Single Supply Op Amp (Rev. B)
    PDF, 313 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note discusses the use of the LM158/LM258/LM358 dual op amp when operated from asingle supply.
  • Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)
    PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits.
  • AN-103 LM340 Series Three Terminal Positive Regulators (Rev. A)
    PDF, 814 Кб, Версия: A, Файл опубликован: 6 май 2013
    The LM340-XX are three terminal 1.0A positive voltage regulators with preset output voltages of 5.0V or15V. The LM340 regulators are complete 3-terminal regulators requiring no external components fornormal operation. However by adding a few parts one may improve the transient response provide for avariable output voltage or increase the output current. Included on the chip are all of t
На английском языке: Datasheet Texas Instruments MC1458CP1
