Datasheet Texas Instruments THS3001CDR — Даташит
СерияTHS3001
МодельTHS3001CDR
Усилитель с токовой обратной связью, 420 МГц 8-SOIC 0–70
420-MHz High-Speed Current-Feedback Amplifiers datasheet
PDF, 1.2 Мб, Версия: H, Файл опубликован: 16 сен 2009
IC OPAMP CFA 1 CIRCUIT 8SOIC. Current Feedback Amplifier 1 Circuit 8-SOIC. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
THS3001CDR
1 058 ₽
THS3001CDR
THS3001CDR
THS3001CDR
Package TypeD
Package QTY2500
Маркировка3001C
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic80 dBc
3rd Harmonic80 dBc
@ MHz10
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Current FB
BW @ Acl420 МГц
CMRR(Min)65 дБ
CMRR(Typ)73 дБ
GBW(Typ)420 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)9 мА
Iq per channel(Typ)6.6 мА
Количество каналов1
Offset Drift(Typ)5 uV/C
Output Current(Typ)120 мА
Rail-to-RailNo
Slew Rate(Typ)6500 V/us
Total Supply Voltage(Max)33 +5V=5, +/-5V=10
Total Supply Voltage(Min)9 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.6 нВ/rtГц
Vn at Flatband(Typ)1.6 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)3 мВ
  • Evaluation Modules & Boards: THS3001EVM
    THS3001 High Speed Amplifier Evaluation Modules
  • Evaluation Modules & Boards: THS3112EVM
    THS3112EVM Evaluation Module
  • Evaluation Modules & Boards: DAC904EVM
    DAC904 14-Bit 165-MSPS Digital-to-Analog Converter (DAC) Evaluation Module
  • Evaluation Modules & Boards: DAC908EVM
    DAC908 8-Bit 165-MSPS Digital-to-Analog Converter (DAC) Evaluation Module
  • Evaluation Modules & Boards: DAC900EVM
    DAC900 10-Bit 165-MSPS Digital-to-Analog Converter (DAC) Evaluation Module
  • Evaluation Modules & Boards: DAC902EVM
    DAC902 12-Bit 165-MSPS Digital-to-Analog Converter (DAC) Evaluation Module
  • Gain Block Analysis For The THS3001
    PDF, 62 Кб, Файл опубликован: 22 мар 1999
    This report describes how to construct a gain block diagram for a current feedback op amp and relates the diagram to stability and gain analysis using parameters of the THS3001 op amp.
  • THS3001 SPICE Model Performance
    PDF, 232 Кб, Файл опубликован: 28 окт 1999
    This application report outlines the SPICE model of the THS3001 high-speed monolithic operational amplifier. General information about the model file structure, performance comparison, model listing, and a brief comment about symbols are included. The listing can be copied and pasted into an ASCII editor, or it can be down loaded by visiting the THS3001 product folder at http://www.ti.com/sc/docs/
  • Analysis of the Sallen-Key Architecture (Rev. B)
    PDF, 92 Кб, Версия: B, Файл опубликован: 13 сен 2002
    This application report discusses the Sallen-Key architecture. The report gives a general overview and derivation of the transfer function, followed by detailed discussions of low-pass and high-pass filters, including design information, and ideal and non-ideal operation. To illustrate the limitations of real circuits, data on low-pass and high-pass filters using the Texas Instruments THS3001 is i
  • Driving Capacitance with the THS3001
    PDF, 45 Кб, Файл опубликован: 12 апр 1999
    Operational amplifiers (op amps) are often used to drive devices that present significant capacitance such as analog-to-digital converters, cables, MOSFETs, filter networks, etc. The effect of the added capacitance is to cause extra phase shift, which tends to erode the phase margin of the amplifier and may lead to instability. At high frequency, even a very small capacitance is detrimental.
  • Building a Simple SPICE Model for the THS3001
    PDF, 114 Кб, Файл опубликован: 15 апр 1999
    The application report Voltage Feedback Versus Current Feedback Op Amps SLVA051 outlines the basic operation of a current feedback operational amplifier (op amp) in relation to a voltage feedback op amp. One of the basic principles of a current feedback op amp is that its transfer function is a transimpedance equal to the output voltage divided by the current from the negative input terminal, i.e.
  • Load Sharing Concepts: Implementation for Large-Signal Applications
    PDF, 219 Кб, Файл опубликован: 5 окт 2011
    Selecting a suitable large-signal swing operational amplifier driver for instrumentation or test and measurement applications can be challenging. In addition to developing the necessary theoretical background for load sharing, this report provides bench results to demonstrate the implementation and benefits of load sharing and output paralleling.
  • Large-Signal Specifications for High-Voltage Line Drivers
    PDF, 195 Кб, Файл опубликован: 30 июн 2011
    Output voltage swing, output current, and slew rate interact with many other specifications in operational amplifiers. This application note develops the definitions for each parameter and the relationship between important ac parameters such as large-signal bandwidth and distortion.
  • A Numerical Solution to an Analog Problem
    PDF, 210 Кб, Файл опубликован: 25 апр 2010
    In order to derive a solution for an analog circuit problem, it is often useful to develop a model. This approach is generally accepted as developing an analytical model. However, finding the analytical solution is not always practical or possible as a result of higher-degree polynomials that require further resolution, or because of the time needed to develop the solution completely. In these sit
  • Voltage Feedback vs. Current Feedback Op Amps
    PDF, 93 Кб, Файл опубликован: 30 ноя 1998
    This application report contrasts and compares the characteristics and capabilities of voltage and current feedback operational amplifiers. The report also points out the many similarities between the two versions.
  • Wireline Data Transmission and Reception
    PDF, 191 Кб, Файл опубликован: 27 янв 2010
    Many types of wires are widely used to transmit data. Specifically, Category 3 and Category 5 (Cat3 and Cat5e, respectively)—also known as unshielded twisted pair or UTP lines—are now recommended for new telephone installations. Coaxial (coax) cables are used to distribute cable television (CATV) signals throughout a home. #12 and #14 American wire gauge (AWG) electric power distribution wire is a
  • PowerPAD Thermally Enhanced Package (Rev. H)
    PDF, 983 Кб, Версия: H, Файл опубликован: 6 июл 2018
На английском языке: Datasheet Texas Instruments THS3001CDR
