Datasheet Texas Instruments TL598CD — Даташит
СерияTL598
МодельTL598CD
Цепь управления широтно-импульсной модуляцией (ШИМ) 16-SOIC 0–70
TL598 datasheet
PDF, 474 Кб, Версия: D, Файл опубликован: 30 окт 2003
Pin16
Package TypeD
Package QTY40
МаркировкаTL598C
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Control MethodVoltage
Duty Cycle(Max)45 %
Frequency(Max)300 kHz
Frequency(Min)1 kHz
Gate Drive(Typ)0.2 A
Special FeaturesAdjustable Switching Frequency,Error Amplifier,Multi-topology
TopologyBoost,Buck,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off4/6 В
Vin(Max)38 В
  • Designing Switch-Mode Power Supplies with the TL598 Application Report (Rev. B)
    PDF, 1.0 Мб, Версия: B, Файл опубликован: 1 июл 1992
    Designers of switching power supplies commonly specify MOSFET switches and therefore need control circuits with outpus capable of directly driving MOSFET switches. The TL598 control circuit was designed with this capability to avoid any need for additional output circuitry. After functionally describing the TL598, this report directs the designer through a complete dc-to-dc converter design using
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments TL598CD
