Datasheet Texas Instruments UCC37323PE4 — Даташит
| Серия | UCC37323 |
| Модель | UCC37323PE4 |
Двойные высокоскоростные драйверы MOSFET с пиковым током 4 А, 8-PDIP, 0–70
UCCx732x Dual 4-A Peak High-Speed Low-Side Power-MOSFET Drivers datasheet
PDF, 1.3 Мб, Версия: I, Файл опубликован: 29 июл 2016
Купить UCC37323PE4 на РадиоЛоцман.Цены — от 30 до 95 ₽10 предложений от 10 поставщиков Dual 4 A Peak High Speed Low-Side Power MOSFET Drivers 8-PDIP 0 to 70 | |||
| UCC37323PE4 Texas Instruments | 61 ₽ | ||
| UCC37323PE4 Texas Instruments | по запросу | ||
| UCC37323PE4 | по запросу | ||
| Pin | 8 |
| Package Type | P |
| Industry STD Term | PDIP |
| JEDEC Code | R-PDIP-T |
| Package QTY | 50 |
| Carrier | TUBE |
| Маркировка | UCC37323P |
| Width (мм) | 6.35 |
| Length (мм) | 9.81 |
| Thickness (мм) | 3.9 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Channel Input Logic | Inverting |
| Fall Time | 15 нс |
| Input Threshold | CMOS,TTL |
| Input VCC(Max) | 15 В |
| Input VCC(Min) | 4.5 В |
| Количество каналов | 2 |
| Рабочий диапазон температур | от 0 до 70 C |
| Package Group | PDIP |
| Peak Output Current | 4 A |
| Power Switch | MOSFET,IGBT,GaNFET |
| Prop Delay | 25 нс |
| Rating | Catalog |
| Rise Time | 20 нс |
| Special Features | Dual Inverting Outputs,Hysteretic Logic |
| Бессвинцовая технология (Pb Free) | Да |
- Evaluation Modules & Boards: UCC3895EVM-001
UCC3895 Evaluation Module
- Synchronous Rectifiers of a Current DoublerPDF, 207 Кб, Файл опубликован: 27 фев 2003
Driving a current doubler synchronous rectification output stage can be a very complex task, especially for a phase shifted full bridge topology. However, using the A and B outputs of the UCC3895 along with the UCC37324 dual 4-A MOSFET driver, direct PWM control of a synchronous rectifier current doubler output stage achieves. This technique provides the proper gating and timing signals necessary
Серия: UCC37323 (10)
- Semiconductors > Power Management > MOSFET and IGBT Gate Drivers > Low-side Driver
