Datasheet Texas Instruments 74AC11011N — Даташит
Серия74AC11011
Модель74AC11011N
Тройные логические элементы положительного И с 3 входами 16-PDIP от -40 до 85
5 предложений от 5 поставщиков
Triple 3-Input Positive-AND Gates 16-PDIP -40 to 85
74AC11011NS16PIN
МосЧип
74AC11011N
74AC11011N
74AC11011NS
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • Live Insertion
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
Серия: 74AC11011 (3)
  • Semiconductors > Logic > Gate > AND Gate
На английском языке: Datasheet Texas Instruments 74AC11011N
