Datasheet Texas Instruments LP5900SDX-2.2/NOPB — Даташит
СерияLP5900
МодельLP5900SDX-2.2/NOPB
Сверхмалошумящий LDO 150 мА для радиочастотных и аналоговых цепей не требует байпасного конденсатора 6-WSON от -40 до 125
LP5900 150-mA Ultra-Low-Noise LDO for RF and Analog Circuits - Requires No Bypass Capacitor datasheet
PDF, 1.6 Мб, Версия: R, Файл опубликован: 1 июн 2016
Pin6
Package TypeNGF
Industry STD TermWSON
JEDEC CodeR-PDSO-N
Package QTY4500
МаркировкаL19
Width (мм)2.2
Length (мм)2.5
Thickness (мм).8
Max Height (мм)8
Accuracy(%)2
Approx. Price (US$)0.20 | 1ku
Fixed Output Options(V)1.5
1.575
1.8
1.9
2
2.1
2.2
2.3
2.5
2.6
2.65
2.7
2.75
2.8
2.85
3.0
3.3
4.5
Iout(Max)(A)0.15
Iq(Typ)(mA)0.025
Noise(uVrms)6.5
Operating Temperature Range(C)-40 to 125
Output Capacitor TypeCeramic
Output OptionsFixed Output
PSRR @ 100KHz(dB)40
Package GroupWSON
Package Size: mm2:W x L (PKG)See datasheet (WSON)
Regulated Outputs(#)1
Special FeaturesEnable
Thermal Resistance ОёJA(В°C/W)80
Vdo(Typ)(mV)80
Vin(Max)(V)5.5
Vin(Min)(V)2.5
Vout(Max)(V)4.5
Vout(Min)(V)1.5
  • Evaluation Modules & Boards: LP5900TL-1.8EV
    Ultra Low Noise, 150mA Linear Regulator for RF Analog Circuits Requires No Bypass Capacitor
  • Evaluation Modules & Boards: LP5900SD-3.3EV
  • Evaluation Modules & Boards: LP5900TL-3.3EV
  • Evaluation Modules & Boards: LP5900TL-3.0EV
  • Evaluation Modules & Boards: LMK61E0MEVM
    LMK61E0M Ultra-Low-Jitter Programmabler Oscillator Evaluation Module
  • Evaluation Modules & Boards: LMK61E2EVM
    LMK61E2EVM Ultra-Low-Jitter Programmable Oscillator Evaluation Module
  • Evaluation Modules & Boards: LP5900SD-2.5EV
  • Evaluation Modules & Boards: LP5900SD-1.8EV
    Ultra Low Noise, 150mA Linear Regulator for RF Analog Circuits Requires No Bypass Capacitor EVM
  • Evaluation Modules & Boards: SP16160CH1RBKIT
    High-IF Sub-sampling Receiver Subsystem
  • Evaluation Modules & Boards: LP5900TL-2.6EV
  • Evaluation Modules & Boards: LP5900TL-2.0EV
  • Evaluation Modules & Boards: LP5900TL-1.5EV
  • Evaluation Modules & Boards: LP5900TL-2.5EV
  • Evaluation Modules & Boards: LP5900SD-2.8EV
  • Evaluation Modules & Boards: LP5900TL-2.8EV
  • Evaluation Modules & Boards: LP5900TL-2.2EV
  • Evaluation Modules & Boards: LP5900SD-3.0EV
  • AN-2145 Power Considerations for SDI Products (Rev. B)
    PDF, 63 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application report discusses the issues and trade-offs that VCC ripple has on the performance of SDI components.
  • AN-1950 Silently Powering Low Noise Applications (Rev. A)
    PDF, 10.5 Мб, Версия: A, Файл опубликован: 22 апр 2013
    This application report explains how to implement a low noise switch mode power supply solution. Itintroduces the sources of noise and explain how to minimize them. A big factor in noise generation andpropagation is the printed circuit board layout. Important basics are discussed. Circuit measurementtechniques are also explained to guide a design engineer towards a low noise but efficient so
  • AN-2146 Power Design for SDI and Other Noise-Sensitive Devices (Rev. A)
    PDF, 1.4 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses various solutions for meeting the power requirements of serial digital interface (SDI) video components.
LP5900SDX2.2/NOPB, LP5900SDX 2.2/NOPB
На английском языке: Datasheet Texas Instruments LP5900SDX-2.2/NOPB
