Datasheet Texas Instruments TMS320C2801PZA — Даташит
СерияTMS320C2801
МодельTMS320C2801PZA
32-битный контроллер цифровых сигналов с ПЗУ 100-LQFP от -40 до 85
Pin100
Package TypePZ
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
ADC (Ch)16
Additional FeaturesSingle Zone Code Security
32-bit CPU Timers
Watchdog Timer
20 pin Oscillator
AEC-Q100 Automotive Qual
Analog to Digital Converter (ADC)ADC12: 2-S/H
6.25-MSPS
CAP2
CPUC28x
Frequency(MHz)100
GPIO35
High Resolution PWM(Ch)3
I2C1
Operating Temperature Range(C)-40 to 125
-40 to 85
Other Actuation FeaturesN/A
Other Connectivity FeaturesCAN
Other Sensing FeaturesN/A
PWM Technology TypeType 0
PWM(Ch)6
Package GroupLQFP
Package Size: mm2:W x L (PKG)100LQFP: 256 mm2: 16 x 16(LQFP)
Processing AcceleratorsN/A
QEP1
RAM(KB)12
ROM (KB)32
SPI2
Total Processing (MIPS)100
UART1
RoHSНе совместим
  • Development Kits: TMDSDOCK2808
    TMS320F2808 Experimenter Kit
  • Evaluation Modules & Boards: TMDSDCDC2KIT
    C2000 Digital Power Experimenter Kit
    Статус продукта: NRND (Не рекомендуется для новых разработок)
  • Evaluation Modules & Boards: TMDSDCDC8KIT
    C2000 DC/DC Developer's Kit
  • Daughter Cards: TMDSCNCD2808
    TMS320F2808 controlCARD
  • JTAG Emulators/ Analyzers: C2000-GANG
    C2000 Gang Programmer
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • Implementing a Spectrum Analyzer Using a 128 Point FFT (Rev. A)
    PDF, 95 Кб, Версия: A, Файл опубликован: 14 июн 1999
    Evaluation module (EVM) application #8 produces a spectrum analyzer using the digital-to-analog converter (DAC) of the Texas Instruments (TI)(tm) TMS320F240 EVM. The spectrum analyzer is produced using a 128-point fast Fourier transform (FFT) with the values collected from the analog-to-digital converter (ADC). The output is produced using the DAC, and the results can be viewed using an oscillosco
  • Interfacing A DSKplus With Flash Memory Daughter Board
    PDF, 160 Кб, Файл опубликован: 9 апр 1998
    This document describes a daughter board that can be plugged onto the TMS320C54x DSK-Plus. It is based on the TMS28F400 4 Megabit bit Flash memory. This application report includes the complete hardware description and the software algorithms that have been successfully tested on the configuration mentioned above.The debug of this kit has been performed using the standard JTAG emulator XDS510 fr
  • Designing a TMS320F280x Based Digitally Controlled DC-DC Switching Power Supply
    PDF, 1.9 Мб, Файл опубликован: 20 июл 2005
    This application report presents a TMS320F280x based digital control design and implementation of a high frequency dc-dc switching power supply. Starting with a dc-dc buck converter and a given set of performance specifications, different control blocks and parameters, used as in the analog control design approach, are reviewed prior to the control design in digital domain. The control loop is the
  • Configuring the TMS320F280x DSP as an I2C Processor
    PDF, 495 Кб, Файл опубликован: 29 июн 2007
    This application report provides details on how to configure a TMS320F280x device so that it can be used as an I2C slave processor and the protocol used to support that configuration.
  • TMS320F28xx and TMS320F28xxx DSP Power Reference Design (Rev. A)
    PDF, 125 Кб, Версия: A, Файл опубликован: 10 апр 2008
    This reference design takes into account the voltage, current, and start-up requirements of the TMS320F280x Digital Signal Processor (DSP) families. The operating input voltage ranges from 3.4 V to 6 V. This design is a high-efficiency solution that provides two voltage rails (1.8-V core supply and 3.3-V I/O supply) and an active-low reset signal to the DSP. This design can be easily adapted to fi
  • TMS320280x and TMS320F2801x ADC Calibration (Rev. A)
    PDF, 218 Кб, Версия: A, Файл опубликован: 6 мар 2007
    This application report describes a method for improving the absolute accuracy of the 12-bit ADC found on the TMS320280x and TMS3202801x devices. Inherent gain and offset errors affect the absolute accuracy of the ADC. The methods described in this report can improve the absolute accuracy of the ADC to levels better than 0.5%.This application report has an option to download an example program
  • TMS320x280x to TMS320x2833x or 2823x Migration Overview (Rev. B)
    PDF, 99 Кб, Версия: B, Файл опубликован: 1 июл 2009
    This application report describes differences between the Texas Instruments TMS320x280x/2801x/2804x and TMS320x2833x/2823x microcontrollers to assist in application migration. While the main focus of this document is migration from 280x/2801x/2804x to 2833x/2823x, you will also find this document useful if you are considering migrating in the reverse direction. Functions that are identical in both
  • 3.3 V DSP for Digital Motor Control
    PDF, 138 Кб, Файл опубликован: 29 апр 1999
    New generations of motor control digital signal processors (DSPs) lower their supply voltages from 5V to 3.3V to offer higher performance at lower cost. Replacing traditional 5V digital control circuitry by 3.3V designs introduce no additional system cost and no significant complication in interfacing with TTL and CMOS compatible components, as well as with mixed voltage ICs such as power transist
  • Optimizing Digital Motor Control Libraries
    PDF, 365 Кб, Файл опубликован: 15 мар 2007
    The DMC library contains a collection of component modules and system implementations, which are intended for evaluation, accelerated design, and development of motor control firmware.The software is intended to meet these goals, and no optimization is performed.As system designers implement systems, they must optimize their systems for performance in terms of memory consumption and CPU cyc
  • Migrating Code Composer v4.12 Projects to Code Composer Studio v2.0
    PDF, 117 Кб, Файл опубликован: 11 июл 2002
    This application report describes the process of migrating an existing Code Composer v4.12 project to a Code Composer Studio? Integrated Development Environment (IDE) v2 project.
  • TMS320x281x to TMS320x280x/2801x/2804x Migration Overview (Rev. A)
    PDF, 124 Кб, Версия: A, Файл опубликован: 5 окт 2006
    This application report describes differences between the Texas Instruments TMS320x281x and TMS320x280x/2801x/2804x DSPs to assist in application migration from the 281x to the 280x. While the main focus of this document is migration from 281x to 280x/2801x/2804x, users considering migrating in the reverse direction (280x to 281x) will also find this document useful. Functions that are identical
  • Using Enhanced Pulse Width Modulator (ePWM) Module for 0-100% Duty Cycle Control
    PDF, 123 Кб, Файл опубликован: 20 дек 2006
    This document provides a guide for the use of the ePWM module to provide 0% to 100% duty cycle control and is applicable to the TMS320x280x family of processors.
  • Configuring Source of Multiple ePWM Trip-Zone Events
    PDF, 93 Кб, Файл опубликован: 25 окт 2007
    Applications that require PWM outputs to respond to multiple trip-zones (TZ) are challenged to determine the specific source of the TZ event.This application report describes how to configure an ePWM module to identify the specific source of a TZ event when multiple TZ events are enabled to act on a single PWM channel.
  • Custom Bootloader Options via One-Time Programmable (OTP) Memory
    PDF, 62 Кб, Файл опубликован: 18 сен 2007
    The Boot to One-Time-Programmable (OTP) memory mode in the TMS320x280x devices provides the necessary hooks to support custom bootloaders. This is very useful in a situation where a bootloader option, required by a specific customer application, is not already supported as one of the built-in options in the Boot read-only memory (ROM). This application report includes information and examples on h
  • Interfacing SD/MMC Cards With TMS320F28xxx DSCs
    PDF, 1.3 Мб, Файл опубликован: 26 июл 2007
    This application report and associated code implements the interfacing of Secure Digital (SD) or Multi-Media Card (MMC) types of Flash memory cards with the TMS320F28xxx digital signal controllers (DSCs). These cards can use serial peripheral interface (SPI) or parallel (SD) interface to connect to the host. This application report demonstrates the SPI mode and includes the schematics showing th
  • Using PWM Output as a Digital-to-Analog Converter on a TMS320F280x (Rev. A)
    PDF, 381 Кб, Версия: A, Файл опубликован: 9 сен 2008
    This application report presents a method for utilizing the on-chip pulse width modulated (PWM) signal generators on the TMS320F280xв„ў family of digital signal controllers as a digital-to-analog converter (DAC). The method involves analog low-pass filtering the PWM signal to remove high frequency components, leaving only the low-frequency content. Theoretical and experimental results are presented
  • An Easy Way of Creating a C-callable Assembly Function for the TMS320C28x DSP
    PDF, 185 Кб, Файл опубликован: 30 окт 2001
    C-callable assembly routines require an understanding of parameter-passing conventions and environments expected by the C compiler. This application report provides instructions and suggestions to configure the C compiler to assist with these issues.
  • Getting Started With TMS320C28x Digital Signal Controllers (Rev. A)
    PDF, 240 Кб, Версия: A, Файл опубликован: 25 окт 2007
    This guide is organized by development flow and functional areas to make your design effort as seamless as possible. Tips on getting started with TMS320C28xв„ў DSP software and hardware development are provided to aid in your initial design and debug efforts. Each section includes pointers to valuable information including technical documentation, software, and tools for use in each phase of d
  • An Overview of Designing Analog Interface With TM320F28xx/28xxx DSCs (Rev. A)
    PDF, 655 Кб, Версия: A, Файл опубликован: 14 май 2008
    This application report provides guidelines that take you through everything from configuring the ADC and related registers correctly, responding to interrupts, and board design recommendations; this may be particularly useful for first-time users of the TMS320C2000в„ў digital signal processor (DSP) platform devices and for firmware engineers with less exposure to the analog world. Various s
  • Online Stack Overflow Detection on the TMS320C28x DSP
    PDF, 407 Кб, Файл опубликован: 2 май 2003
    A stack overflow in an embedded DSP application generally produces a catastrophic software crash due to data corruption, lost return addresses, or both. Traditional off-line approaches to sizing a stack during development, such as filling with a know value, or estimating based on code content, are not 100% reliable. Therefore, programmers often feel compelled to reserve larger stack sizes than are
  • Programming TMS320x28xx and 28xxx Peripherals in C/C++ (Rev. D)
    PDF, 530 Кб, Версия: D, Файл опубликован: 27 фев 2013
    This application report explores a hardware abstraction layer implementation to make C/C++ coding easier on C28x devices. This method is compared to traditional #define macros and topics of code efficiency and special case registers are also addressed.
  • Flash Programming Solutions for the TMS320F28xxx DSCs
    PDF, 423 Кб, Файл опубликован: 19 авг 2008
    Flash programming is a process that occurs during all stages of a TMS320F28xxx digital signal controller (DSC) development cycle: firmware debug, prototyping, production, and field reprogramming. Several solutions are available to accommodate programming for all of these development stages. This application report presents solutions that are available and at what stage in the development cycle the
  • Calculator for CAN Bit Timing Parameters
    PDF, 37 Кб, Файл опубликован: 22 мар 2016
    Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat
  • Programming External Nonvolatile Memory Using SDFlash for TMS320C28x Devices
    PDF, 2.0 Мб, Файл опубликован: 16 ноя 2009
    The C28xxx generation of microcontrollers can connect to external nonvolatile memory through a variety of interfaces including parallel, serial peripheral interface (SPI), and inter-integrated circuit (I2C). This application report discusses how to write drivers for your external nonvolatile memory to allow for in-place programming using SDFlash, an application provided by Spectrum Digital, Inc. A
  • TPS75005 Quick-Start Guide with C2000 Controllers
    PDF, 129 Кб, Файл опубликован: 17 янв 2012
    The TPS75005 is a complete power management solution for C2000 controllers from Texas Instruments. This document illustrates how to attach the TPS75005 to a C2000 controller.
  • Common Object File Format (COFF)
    PDF, 125 Кб, Файл опубликован: 15 апр 2009
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > Fixed-point F280x/1x
На английском языке: Datasheet Texas Instruments TMS320C2801PZA
