Оптопары и оптореле Megawin
Datasheet Texas Instruments TPS56121DQPT — Даташит
СерияTPS56121
МодельTPS56121DQPT
Входное напряжение от 4,5 В до 14 В, ток 15 А, синхронный понижающий преобразователь SWIFT™ 22-LSON-CLIP от -40 до 125
TPS56121 4.5-V to 14-V Input High-Current Synchronous Buck SWIFTв„ў Converter datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 9 фев 2016
Pin22
Package TypeDQP
Industry STD TermLSON-CLIP
JEDEC CodeR-PSSO-N
Package QTY250
CarrierSMALL T&R
МаркировкаTPS56121
Width (мм)5
Length (мм)6
Thickness (мм)1.5
Pitch (мм).5
Max Height (мм)1.5
Control ModeVoltage Mode
Duty Cycle(Max)93 %
Iout(Max)15 A
Iq(Typ)2.5 мА
Package GroupLSON-CLIP
Regulated Outputs1
Special FeaturesAdjustable Current Limit,Enable,Power Good,Pre-Bias Start-Up,Synchronous Rectification
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)300 kHz
ТипConverter
Vin(Max)14 В
Vin(Min)4.5 В
Vout(Max)12 В
Vout(Min)0.6 В
  • Evaluation Modules & Boards: TPS56121EVM-601
    Evaluation Module for TPS56121 High Current (15A) Synchronous Step-Down SWIFTВ™ Converter
  • Calculating Efficiency
    PDF, 175 Кб, Файл опубликован: 19 фев 2010
    This application report provides a step-by-step procedure for calculating buck converter efficiency and power dissipation at operating points not provided by the data sheet.
  • Demystifying Type II and Type III Compensators Using Op-Amp and OTA for DC/DC Co
    PDF, 782 Кб, Файл опубликован: 11 июл 2014
  • Understanding Thermal Dissipation and Design of a Heatsink
    PDF, 59 Кб, Файл опубликован: 4 май 2011
    Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
Серия: TPS56121 (3)
На английском языке: Datasheet Texas Instruments TPS56121DQPT
