Datasheet Texas Instruments SN74LVTH652PW — Даташит
СерияSN74LVTH652
МодельSN74LVTH652PW
Приемопередатчики и регистры октальной шины ABT 3,3 В с выходами с 3 состояниями 24-TSSOP от -40 до 85
SN54LVTH652, SN74LVTH652 datasheet
PDF, 868 Кб, Версия: F, Файл опубликован: 13 окт 2003
26 предложений от 16 поставщиков
Микросхема Логический контроллер, 3.3V ABT Octal Bus Transceivers And egisters With 3-State Outputs 24-TSSOP -40℃ to 85℃
SN74LVTH652PW
от 36 ₽
SN74LVTH652PW
113 ₽
SN74LVTH652PW
120 ₽
SN74LVTH652PW
235 ₽
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY60
МаркировкаLXH652
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Bits8
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)0.005 мА
Output Drive (IOL/IOH)(Max)-32/64 мА
Package GroupTSSOP
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4.7 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Registered Transceiver
На английском языке: Datasheet Texas Instruments SN74LVTH652PW
