Datasheet Texas Instruments SN74ALS245A-1DWG4 — Даташит
| Серия | SN74ALS245A |
| Модель | SN74ALS245A-1DWG4 |
Восьмеричные шинные трансиверы с выходами с 3 состояниями 20-SOIC от 0 до 70
SN54ALS245A, SN54AS245, SN74ALS245A, SN74AS245 datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 13 янв 2003
Купить SN74ALS245A-1DWG4 на РадиоЛоцман.Цены — от 29 до 64 ₽11 предложений от 11 поставщиков IC TXRX NON-INVERT 5.5V 20SOIC. Transceiver, Non-Inverting 1 Element 8 Bit per Element 3-State Output 20-SOIC. Logic - Buffers, Drivers, Receivers,... | |||
| SN74ALS245A-1DWG4 Texas Instruments | 58 ₽ | ||
| SN74ALS245A-1DWG4 Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | DW |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 25 |
| Carrier | TUBE |
| Маркировка | ALS245A-1 |
| Width (мм) | 7.5 |
| Length (мм) | 12.8 |
| Thickness (мм) | 2.35 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.65 |
| Mechanical Data | Скачать |
| Bits | 8 |
| F @ Nom Voltage(Max) | 75 Mhz |
| ICC @ Nom Voltage(Max) | 58 мА |
| Рабочий диапазон температур | от 0 до 70 C |
| Output Drive (IOL/IOH)(Max) | -15/24 мА |
| Package Group | SOIC |
| Package Size: mm2:W x L | 20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | ALS |
| VCC(Max) | 5.5 В |
| VCC(Min) | 4.5 В |
| Voltage(Nom) | 5 В |
| tpd @ Nom Voltage(Max) | 10 нс |
- Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
Серия: SN74ALS245A (20)
- SN74ALS245A-1DW SN74ALS245A-1DWG4 SN74ALS245A-1DWR SN74ALS245A-1DWRG4 SN74ALS245A-1N SN74ALS245A-1NE4 SN74ALS245A-1NSR SN74ALS245ADBLE SN74ALS245ADBR SN74ALS245ADBRG4 SN74ALS245ADW SN74ALS245ADWG4 SN74ALS245ADWR SN74ALS245ADWRE4 SN74ALS245ADWRG4 SN74ALS245AN SN74ALS245AN3 SN74ALS245ANE4 SN74ALS245ANSR SN74ALS245ANSRG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
SN74ALS245A1DWG4, SN74ALS245A 1DWG4
