Datasheet Texas Instruments MSP430FR4131IG56 — Даташит
СерияMSP430FR4131
МодельMSP430FR4131IG56
Микроконтроллер со сверхнизким энергопотреблением, 16 МГц, 4 КБ FRAM, 0,5 КБ SRAM, 60 входов/выходов, 10-битный АЦП, ЖК-дисплей, ИК-логика 56-TSSOP от -40 до 85
MSP430FR413x Mixed-Signal Microcontrollers datasheet
PDF, 1.8 Мб, Версия: B, Файл опубликован: 14 авг 2015
Pin56
Package TypeDGG
Industry STD TermTSSOP
Package QTY35
МаркировкаFR4131
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
ADCADC10 - 10ch
AESN/A
Active Power126 uA/MHz
Additional FeaturesLCD,Real-Time Clock,Watchdog,Temp Sensor,Brown Out Reset
BSLUART
CPUMSP430
Featuredfr4
Тактовая частота16 МГц
GPIO Pins60
I2C1
Max VCC3.6
Min VCC1.8
MultiplierN/A
Non-volatile Memory4 KB
Package GroupTSSOP
Package Size: mm2:W x L48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
RAM0.5 KB
SPI2
Security EnablerCryptographic acceleration,Debug security,Physical security,Secure FW and SW update,Software IP protection
Special I/ON/A
Standby Power1.31 LPM3-uA
Timers - 16-bit2
UART1
Wakeup Time10 us
  • Evaluation Modules & Boards: MSP-FET430U64D
    Target development board (64-pin) and MSP-FET programmer bundle for MSP430FR2x/4x MCUs
  • Evaluation Modules & Boards: MSP-EXP430FR4133
    MSP430FR4133 LaunchPad Development Kit
  • Evaluation Modules & Boards: MSP-TS430PM64D
    Target Development Board – 64 pins – for MSP430FR2x/4x MCUs
    MSP EnergyTrace Technology
  • Migrating from the MSP430F4xx to Family to the MSP430FR4xx Family
    PDF, 194 Кб, Файл опубликован: 3 окт 2014
    This application report enables easy migration from MSP430F4xx flash-based MCUs to the MSP430FR4xx/FR2xx family of FRAM-based MCUs. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR4xx/FR2xx devices, see the MSP430FR4xx and MSP430FR2xx Family User
  • Infrared Remote Control Implementation With MSP430FR4xx (Rev. B)
    PDF, 329 Кб, Версия: B, Файл опубликован: 30 июн 2015
    This application report provides an insight into several of the most frequently used infrared protocols and especially their flexible implementation using the TI MSP430FR4xx series of low-power microcontrollers.The MSP430FR4xx microcontrollers are primarily targeted at remote control application that are equipped with infrared modulation function and an LCD display. The infrared modulation combi
  • VLO Calibration on the MSP430FR4xx and MSP430FR2xx Family (Rev. A)
    PDF, 78 Кб, Версия: A, Файл опубликован: 19 фев 2016
    MSP430FR4xx and MSP430FR2xx (FR4xx/FR2xx) family microcontrollers (MCUs) provide various clock sources, including some high-speed high-accuracy clocks and some low-power low-system-cost clocks. Users can select the best balance of performance, power consumption, and system cost. The on-chip very low-frequency oscillator (VLO) is a clock source with 10-kHz typical frequency included in FR4xx/FR2xx
  • MSP430 FRAM Technology – How To and Best Practices
    PDF, 326 Кб, Файл опубликован: 23 июн 2014
    FRAM is a non-volatile memory technology that behaves similar to SRAM while enabling a whole host of new applications, but also changing the way firmware should be designed. This application report outlines the how to and best practices of using FRAM technology in MSP430 from an embedded software development perspective. It discusses how to implement a memory layout according to application-specif
  • MSP430 FRAM Quality and Reliability (Rev. A)
    PDF, 295 Кб, Версия: A, Файл опубликован: 1 май 2014
    FRAM is a nonvolatile embedded memory technology and is known for its ability to be ultra-low power while being the most flexible and easy-to-use universal memory solution available today. This application report is intended to give new FRAM users and those migrating from flash-based applications knowledge on how FRAM meets key quality and reliability requirements such as data retention and endura
  • MSP430 Embedded Application Binary Interface
    PDF, 596 Кб, Файл опубликован: 16 май 2012
    This document is a specification for the ELF-based Embedded Application Binary Interface (EABI) for the MSP430 family of processors from Texas Instruments. The EABI defines the low-level interface between programs, program components, and the execution environment, including the operating system if one is present. Components of the EABI include calling conventions, data layout and addressing conve
  • Migrating From MSP430 F2xx and G2xx Families to MSP430 FR4xx and FR2xx Family (Rev. E)
    PDF, 237 Кб, Версия: E, Файл опубликован: 4 май 2018
    This application report helps to ease the migration from MSP430F2xx flash-based MCUs to the MSP430FR4xx and MSP430FR2xx family of FRAM-based MCUs. It discusses programming system hardware core architecture and peripheral considerations. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR4xx and MSP430FR2xx devices see the MSP430
  • Designing With MSP430 and Segment LCDs (Rev. A)
    PDF, 2.1 Мб, Версия: A, Файл опубликован: 20 июл 2015
    Segment liquid crystal displays (LCDs) are needed to provide information to users in a wide variety of applications from smart meters to electronic shelf labels (ESL) to medical equipment. Several MSP430в„ў microcontroller families include built-in low-power LCD driver circuitry that allows the MSP430 MCU to directly control the segmented LCD glass. This application note helps explain how segmented
  • General Oversampling of MSP ADCs for Higher Resolution (Rev. A)
    PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
    Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430FRxx FRAM
На английском языке: Datasheet Texas Instruments MSP430FR4131IG56
