Datasheet Texas Instruments SM320C6678ACYPW — Даташит
СерияSM320C6678-HIREL
МодельSM320C6678ACYPW
Многоядерный процессор цифровых сигналов с фиксированной и плавающей запятой 841-FCBGA от -55 до 115
SM320C6678-HIREL Multicore Fixed and Floating-Point Digital Signal Processor datasheet
PDF, 2.1 Мб, Версия: A, Файл опубликован: 3 апр 2014
Pin841841841
Package TypeCYPCYPCYP
Package QTY444444
CarrierTUBETUBETUBE
МаркировкаW@2010 TISM320C6678ACYP
Width (мм)242424
Length (мм)242424
Thickness (мм)2.822.822.82
DSP8 C66x
DSP MHz1000 Max.
I2C1
On-Chip L2 Cache4096 KB
Рабочий диапазон температурот -55 до 115 C
SPI1
  • JTAG Emulators/ Analyzers: TMDSEMU560V2STM-U
    XDS200 USB Debug Probe
  • SerDes Implementation Guidelines for KeyStone I Devices
    PDF, 590 Кб, Файл опубликован: 31 окт 2012
    The goal of KeyStone I SerDes collateral material is to make system implementation easier for the customer by providing the system solution. For these SerDes-based interfaces, it is not assumed that the system designer is familiar with the industry specifications, SerDes technology, or RF/microwave PCB design. However, it is still expected that the PCB design work will be supervised by a knowledge
  • Hardware Design Guide for KeyStone Devices (Rev. C)
    PDF, 1.7 Мб, Версия: C, Файл опубликован: 15 сен 2013
  • KeyStone I DDR3 Initialization (Rev. E)
    PDF, 114 Кб, Версия: E, Файл опубликован: 28 окт 2016
    The initialization of the DDR3 DRAM controller on KeyStone I DSPs is straightforward as long as the proper steps are followed. However, if some steps are omitted or if some sequence-sensitive steps are implemented in the wrong order, DDR3 operation will be unpredictable.All DDR3 initialization routines must contain the basic register writes to configure the memory controller within the DSP
  • TMS320C66x DSP Generation of Devices (Rev. A)
    PDF, 245 Кб, Версия: A, Файл опубликован: 25 апр 2011
  • PCIe Use Cases for KeyStone Devices
    PDF, 320 Кб, Файл опубликован: 13 дек 2011
  • Optimizing Loops on the C66x DSP
    PDF, 585 Кб, Файл опубликован: 9 ноя 2010
  • The C6000 Embedded Application Binary Interface Migration Guide (Rev. A)
    PDF, 20 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    The C6000 compiler tools support a new ELF-based ABI named EABI. Prior to this time, the compiler only supported a single ABI, which is now named COFF ABI. The following compelling best-in-class features are available under the C6000 EABI:GeneralZero-init globals: “int gvar;” gets set to 0 before main runs.Dynamic linking: Add code to a running system.Native ROM
  • Clocking Design Guide for KeyStone Devices
    PDF, 1.5 Мб, Файл опубликован: 9 ноя 2010
  • DDR3 Design Requirements for KeyStone Devices (Rev. B)
    PDF, 582 Кб, Версия: B, Файл опубликован: 5 июн 2014
  • Multicore Programming Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 29 авг 2012
    As application complexity continues to grow, we have reached a limit on increasing performance by merely scaling clock speed. To meet the ever-increasing processing demand, modern System-On-Chip solutions contain multiple processing cores. The dilemma is how to map applications to multicore devices. In this paper, we present a programming methodology for converting applications to run on multicore
Серия: SM320C6678-HIREL (1)
  • SM320C6678ACYPW
  • Semiconductors > Space & High Reliability > Processor > Digital Signal Processor > C6000 DSPs
На английском языке: Datasheet Texas Instruments SM320C6678ACYPW
