Datasheet Texas Instruments TMX320C6211GFN — Даташит
СерияTMS320C6211
МодельTMX320C6211GFN
Процессор цифровых сигналов с фиксированной точкой 256-BGA от 0 до 0
Pin256
Package TypeGFN
Industry STD TermBGA
JEDEC CodeS-PBGA-N
Width (мм)27
Length (мм)27
Thickness (мм)1.72
Max Height (мм)2.32
RoHSНе совместим
  • TMS320C6211 to TMS320C6211B Migration Guide
    PDF, 51 Кб, Файл опубликован: 28 апр 2003
    This document describes migration from the TMS320C6211 to the TMS320C6211B. The objective of this document is to indicate differences between the two devices and show how handle these differences. Depending on the board layout and any system level timing assumptions, a migration may or may not require any changes. If changes are required, some systems may be able to implement any necessary timing
  • Migrating From TMS320C6211B/C6711/C6711B/C6711C to TMS320C6711D (Rev. H)
    PDF, 155 Кб, Версия: H, Файл опубликован: 10 ноя 2005
    This document describes issues of interest related to migration from the Texas Instruments TMS320C6211B/C6711/C6711B GFN package and TMS320C6711C GDP package to the TMS320C6711D digital signal processor (DSP) GDP package. The objective of this document is to indicate differences between these devices. Functions that are identical between these devices are not included. For detailed information on
  • Migrating from TMS320C6211B/C6711/C6711B and C6713 to TMS320C6713B (Rev. H)
    PDF, 155 Кб, Версия: H, Файл опубликован: 11 ноя 2005
    This document describes issues of interest related to migration from the Texas Instruments TMS320C6211B/C6711/C6711B GFN package and TMS320C6713 GDP package to the TMS320C6713B digital signal processor (DSP) GDP package. The objective of this document is to indicate differences between these devices. Functions that are identical between these devices are not included. For detailed information on t
  • TMS320C62x/C67x Power Consumption Summary (Rev. C)
    PDF, 114 Кб, Версия: C, Файл опубликован: 30 июл 2002
    This document discusses the power consumption of the Texas Instruments TMS320C6201B, TMS320C6701, TMS320C6202, TMS320C6202B, TMS320C6203, TMS320C6204, TMS320C6205, TMS320C6211, and TMS320C6711 digital signal processors (DSPs) for typical applications. The C6201B, C6701, C6202, C6211, and C6711 DSPs are manufactured on TI's advanced 0.18-micron process and operate with a core voltage of 1.8 V. The
  • TMS320C6000 EDMA IO Scheduling and Performance
    PDF, 269 Кб, Файл опубликован: 5 мар 2004
    The enhanced DMA (EDMA) is a highly efficient and parallel data transfer engine. To make the best use of its resources, it is necessary to understand the architecture and schedule transfers intelligently. This document details how to summarize, analyze, and schedule system traffic to produce efficient designs. An example audio/video system is presented and analyzed in full. Finally, EDMA performan
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP > Other C6000 DSP
На английском языке: Datasheet Texas Instruments TMX320C6211GFN
