Линейка продуктов KEEN SIDE
Datasheet Texas Instruments UC3863DW — Даташит
СерияUC3863
МодельUC3863DW
Контроллеры источников питания резонансного режима 16-SOIC от 0 до 70
Resonant-Mode Power Supply Controllers datasheet
PDF, 3.9 Мб, Версия: B, Файл опубликован: 13 сен 2007
Pin16
Package TypeDW
Package QTY40
МаркировкаUC3863DW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Control MethodVoltage
Duty Cycle(Max)50 %
Frequency(Max)500 kHz
Frequency(Min)50 kHz
Gate Drive(Typ)1 A
Special FeaturesError Amplifier,Green Mode,Light Load Efficiency,Multi-topology,Soft Start,Soft Switching
TopologyFull-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off8/7 В
Vin(Max)22 В
Vin(Min)7 В
  • U-138 Zero Voltage Switching Resonant Power Conversion
    PDF, 794 Кб, Файл опубликован: 5 сен 1999
    This application note explores the technique of zero voltage switching in modern power conversion. It describes several ZVS topologies and applications limitations of the ZVS technique and a generalized design procedure. Two design examples are presented: a 50W DC/DC converter and an off-line 300W multiple output power supply. This discussion concludes with a performance comparison of ZVS conve
  • U-122 A New Family of Integrated Circuits Controls Resonant Mode Power
    PDF, 272 Кб, Файл опубликован: 5 сен 1999
    This application note introduces the UC3861-8 family of ICs which are optimized for the control of zero-current-switched and zero-voltage-switched quasi-resonant converters. Differences among members of this device family result from the various combinations of UVLO thresholds and output options. The one-shot pulse steering logic is configured to program either on time for ZCS systems (UC1865-186
Серия: UC3863 (2)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC3863DW
