Datasheet Texas Instruments AMC1210IRHAT — Даташит
СерияAMC1210
МодельAMC1210IRHAT
4-канальный цифровой фильтр для модуляторов семейства ADS120X 40-VQFN от -40 до 125
Quad Digital Filter for 2nd-Order Delta-Sigma Modulator datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 8 май 2009
Pin4040
Package TypeRHARHA
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
Маркировка1210IAMC
Width (мм)66
Length (мм)66
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
# Input Channels4
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)4.5 В
АрхитектураSpecial
Digital Supply(Max)5.5 В
InterfaceParallel,Serial SPI
Package GroupVQFN
Package Size: mm2:W x L40VQFN: 36 mm2: 6 x 6(VQFN) PKG
Power Consumption(Typ)24.5 mW
Sample Rate (max)40kSPS SPS
Sample Rate(Max)0.04 MSPS
  • Evaluation Modules & Boards: AMC1210MB-EVM
    AMC1210 Mother Board
  • Evaluation Modules & Boards: AMC1203EVM
    AMC1203 Evaluation Module
  • Evaluation Modules & Boards: AMC1204EVM
    AMC1204 Evaluation Module
  • Using the AMC1210 in Resolver Motor Control Systems
    PDF, 256 Кб, Файл опубликован: 18 май 2006
    Resolver motor control systems typically have used either closed-loop Resolver-to-Digital Converters (RDCs) or open-loop Analog-to-Digital Converters (ADCs) to obtain position and velocity data from the resolver outputs. TI has developed a new method of resolver decoding using the dual delta-sigma modulator ADS1205 and the AMC1210, a digital filter device designed specifically for use in motor con
  • Closed-loop motor control: An introduction to rotary resolvers and encoders
    PDF, 716 Кб, Файл опубликован: 11 апр 2014
Серия: AMC1210 (3)
  • Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > Isolated ADCs
На английском языке: Datasheet Texas Instruments AMC1210IRHAT
