Datasheet Texas Instruments SN65HVD3082EDG4 — Даташит
СерияSN65HVD3082E
МодельSN65HVD3082EDG4
Полудуплексный трансивер RS-485 8-SOIC от -40 до 85
SNx5HVD308xE Low-Power RS-485 Transceivers, Available in a Small MSOP-8 Package datasheet
PDF, 1.2 Мб, Версия: I, Файл опубликован: 28 сен 2016
IC TRANSCEIVER HALF 1/1 8SOIC. 1/1 Transceiver Half RS422, RS485 8-SOIC. Interface - Drivers, Receivers, Transceivers
Рутоника
SN65HVD3082EDG4
112 ₽
Hi-Tech Circuit Group
SN65HVD3082EDG4
МосЧип
SN65HVD3082EDG4
SN65HVD3082EDG4
Package TypeD
Package QTY75
МаркировкаVP3082
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Common Mode Range-7 to 12
DuplexHalf
Fail SafeIdle,Open,Short
Fault Protection-9 to 14 В
HBM ESD15 kV
ICC(Max)0.9 мА
IEC 61000-4-2 ContactN/A +/- kV
IsolatedNo
No. of RX1
No. of TX1
Number of Nodes256
Signaling Rate(Max)0.2 Mbps
Supply Voltage(s)(Nom)5 В
  • Evaluation Modules & Boards: RS485-HF-DPLX-EVM
    RS-485 Half-Duplex Evaluation Module
  • RS-485 for E-Meter Applications (Rev. A)
    PDF, 311 Кб, Версия: A, Файл опубликован: 6 авг 2004
    This application report discusses the best practices for designing energy meter communication circuits using the RS-485 standard. Component selection and performance tradeoffs are covered with reference to relevant standards such as IEC 61036 and DL/T 645. Reference design details are provided to help energy meter engineers successfully complete their own circuit designs.
На английском языке: Datasheet Texas Instruments SN65HVD3082EDG4
